Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Posting pictures?
Old Dec 27, 2003 | 03:25 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Posting pictures?
How do you post pictures on these boards?
Old Dec 27, 2003 | 05:21 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
You can use the attachment feature. When posting a reply there is a Browse button just above the submit post button. Click on browse and find the picture that you want to use. Then when you click the submit post button your pic will show up in the post.
You can only attach 1 picture per post.
IF you want to do more than 1 in a post then you must remote link the pics.
If you have a cardomain page then you can hot link the pics.
Click on the picture that you want, the right click on it and a box will pop up. Select properties and then copy the url/address in the new popup box.
Now in the thread you use the IMG tags, located just above the text box that you type in.
Paste that url in and the pic will show up. IE,
the address of the thirdgen.org pic is,
https://www.thirdgen.org/techbb2/images/vbblogo.gif
Now by putting in the IMG tas
[ img ]https://www.thirdgen.org/techbb2/images/vbblogo.gif[ /img ] I have to put the spaces inbetween the [ and img. When you take them out you will get this,
Old Jan 3, 2004 | 09:46 PM
Dark Man C's Avatar
Car: 1989 Trans Am GTA
Engine: 350 5.7 L98
test
Old Jan 4, 2004 | 08:50 PM
Car: 85 Camaro SC
Engine: V6
Take out the space's inbetween the [ img ] and [/ img] then the pic will work. Also make sure the brackets have no spaces inbetween them and your url.
I had to put it like that or no one would have been able to see what I was talking about.
Old Jan 5, 2004 | 05:01 PM
Dark Man C's Avatar
Engine: 350 5.7 L98
Thanks 85SPORTCOUPETO89RS...'PRECIATE THE HELP...ALOT!!!
Old Mar 10, 2004 | 12:43 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
did this work?
TEST
This is my motor, new pics will be up soon, this is out dated
This is my first time posting, lets see if it works.
[IMG]C:\Documents and Settings\Lowerf\Desktop\old motor pic.jpg[/IMG]
DAM STILL NOT WORKING???
Do I have to have my pics already on the net? Where do I go to download pics onto the net so I can load them on this site?? And how?
Old Mar 10, 2004 | 12:55 PM
JT's Avatar
JT
Community Administrator
Yes, you must have them online somewhere. You can't link to pictures from your pc.
Usually, your ISP offers some type of storage space where you can upload your pictures to so that you can link to them.
Or, you can make use of the attachment feature in your posts by uploading your image from your pc to TGO's server. To do that, simply click the Browse button on the "Attach File" line, which is under the reply box. Find the image from your pc, then select Ok/open.
Then post the message as normal. Your image will then be uploaded to TGO's server, provided that your image is an accepted type (jpg gif png jpeg bmp) and isn't larger than 102500 bytes.
Originally posted by GOFASTER
did this work?
TEST
Old Mar 10, 2004 | 01:48 PM
GOFASTER's Avatar
Engine: 388 ci
test
crap
Old Mar 10, 2004 | 01:50 PM
GOFASTER's Avatar
Engine: 388 ci
dam I got it to post the url, but why not the picture??
Old Mar 10, 2004 | 02:10 PM
JT's Avatar
JT
Try removing the question mark and everything after that in your URL, end it with the jpg. vB code doesn't like URLs like that for the vB image tag script.
Old Mar 10, 2004 | 02:14 PM
GOFASTER's Avatar
Engine: 388 ci
Okay, TEST
thanks for the help by the way
Old Mar 10, 2004 | 02:15 PM
GOFASTER's Avatar
Engine: 388 ci
YESSSSSSSSSSSSSSSS FINALLY I HAVE BEEN ON THIS SITE FOR 4 YEARS AND NEVER KNEW HOW TO DO THAT...
YOUR THE MAN!!!
Old Mar 11, 2004 | 09:39 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Test
Old Mar 13, 2004 | 10:46 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
testing
Old Mar 13, 2004 | 10:47 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
wow that was big
Old Mar 13, 2004 | 10:53 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
testing
Old Apr 4, 2004 | 08:01 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Testing!
Old Apr 9, 2004 | 10:35 PM
SEEJGO's Avatar
Car: 1992 Z-28
Engine: 400 Olds Rocket
Transmission: Coan TH400
Test
Test
Old Apr 9, 2004 | 10:37 PM
SEEJGO's Avatar
Car: 1992 Z-28
Test
Old Apr 12, 2004 | 09:43 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Test...
The file that you have tried to attach is too big. The maximum size is 102500 bytes.
That's the message I get every time since I got my new camera. Do I have to resize or what??
Old Apr 12, 2004 | 10:19 AM
JT's Avatar
JT
Yes, if it's a new camera and you're using a high resolution, that will definitely occur and you will need to resize the picture down in order to be below the current Maximum size of 102500 bytes.
Old Apr 16, 2004 | 01:28 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
And for the computer challenged people like myself, how would one go about doing that?
Old Apr 26, 2004 | 11:54 AM
ChevyGuy5's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
test
Old Apr 26, 2004 | 11:40 PM
Confuzed1's Avatar
Car: 83Z28 HO
Trying again...
Old May 10, 2004 | 09:45 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Testing
Too Big maybe??
Old May 10, 2004 | 10:16 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Trying again, this time resized from computer.
Old Oct 27, 2007 | 10:06 PM
purdybird824's Avatar
Car: 1989 Formula
Engine: LO3
Axle/Gears: 2.73 -> 3.27 9 Bolt
Re: Posting pictures?
yet another test...
Old Sep 24, 2008 | 12:35 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
[IMG][/IMG]test
z28_AJ
Aug 27, 2015 08:59 PM
chubsworth
Aug 26, 2015 02:34 AM
LittleFranks
Aug 20, 2015 03:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
BigJon88
Aug 19, 2015 10:17 AM
