Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Attached Pics come up as a Link, not a PIC??
Old Mar 24, 2005 | 12:26 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Since the site has come back up, whenever I post a pic it comes up a link, and not an attachment showing the pic???? Am I doing something wrong? The pics are small enough and should post up? I just want my pretty pictures to be seen....
Old Mar 24, 2005 | 03:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You mean like your sig pic? That's coming up fine. Link to examples maybe? Did your host site pull a geocities maybe?
Old Mar 24, 2005 | 03:55 PM
JT's Avatar
JT
Community Administrator
i think he means like this:
https://www.thirdgen.org/techbb2/sho...hreadid=278418
One of the moderators here has that same issue.
The file appears to still get uploaded into the database, but something is happening (incorrectly) at that point. Likely something only Dirk can dig into and fix.
Old Mar 24, 2005 | 09:23 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
I had that problem a while back. IIRC I updated my IE and never had a problem again. I also swapped computers a week later so I can't wholeheartedly attribute the update to the fix.
Used to be that you could hit 'edit' to see how they entered everything, that doesn't work now so I can't see if they typed it in or if they tried it as an attachment. Maybe they could try using the html tag method to see if that works for them?
Old Mar 24, 2005 | 09:32 PM
JT's Avatar
JT
At first i wondered if it wasn't browser related, and was going to ask what browser was being used when to upload these files.
In the other case, i was able to download the attachment that was posted, despite the fact that the link appeared to be local to that user's computer. So the file does upload into the database. It's up to the software to properly link the file, which appears to be the issue here. Since the file is uploading into the database, it would seem to me that the issue possibly could be on TGO's end, since the user's end is sort of already "finished" its job by having supplied the file. i would think.
However, i never ran the attachment feature, so i have little experience with it.
Old Mar 25, 2005 | 02:30 AM
911rsq's Avatar
Transmission: yes
I guess this all makes sense...I will PM Dirk to see what's up. I had noticed that OkFoz was having the same prob....
Thanks all
Edit - Apparently you cannot PM Dirk....He is un-PMable... I will now attempt to email him....
Old Mar 25, 2005 | 02:38 AM
911rsq's Avatar
Transmission: yes
Just checking.....
Old Mar 25, 2005 | 05:20 AM
911rsq's Avatar
Transmission: yes
Email sent....I hope Dirk can figure it all out.....
I have faith....
Old Mar 25, 2005 | 10:18 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Let's make sure it isn't the pic...
Attached Thumbnails Attached Pics come up as a Link, not a PIC??-c-documents-settings-george
Old Mar 25, 2005 | 10:20 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by JT
... i was able to download the attachment that was posted, despite the fact that the link appeared to be local to that user's computer. So the file does upload into the database. ...
That's what used to happen to me. It would seemingly upload fine, but would show up as above rather than as a pic. 911rsq (and anyone else that's having problems) post up what browser and version you are running. Granted it's a stab in the dark... :shrug:
Old Mar 25, 2005 | 11:54 AM
JT's Avatar
JT
Yes, it may help to know what browser they are running, and if any firewall/security programs. i think it may be a long shot though, as you can see the picture is getting uploaded into the database. Same as the other example in the other thread. Since the software is what properly links the file, that is why it seems it may be a TGO software glitch. Instead, it keeps the local link. However, as i mentioned, i didn't run the attachment feature so i have little experience and knowledge.
If it turns out to be a glitch in the system, since Dirk is upgrading to a new server, and may also be upgrading to vB 3.x sometime i would think, the issue may be on hold and may even go away with the upgrade, if it isn't a user related issue.
Old Mar 26, 2005 | 04:35 PM
911rsq's Avatar
Transmission: yes
I am running thru internet explorer thru my local cable company.
RedDevil...u said this used to happen to you.... any ideas on why it stopped doing it????
It really sux not being able to post them up.
P.S. - That's NOT my car....
Old Mar 26, 2005 | 05:08 PM
JT's Avatar
JT
Without knowing much about the attachment feature at this time, and being only on the user side, it is a stab in the dark.
But what version of IE are you using? Also, are you using Windows XP Service Pack 2? Or XP Service Pack 1?
Also, are you running any third party type security programs? Such as Norton Security?
If I was you, to help eliminate a lot of this, i'd download and try FireFox. FireFox is a fast growing, free, browser program. It has pros and cons just as Internet Explorer.
Perhaps give FireFox a download and a quick try here to see if you can use the attachment feature or not.
http://www.mozilla.org/products/firefox/
Old Mar 26, 2005 | 05:39 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Same problem, everything worked great (posted pictures) before the site crashed. Now I can't post any pictures without a link from my personal files coming up. So when can this be corrected??? Soon I hope.
Old Mar 28, 2005 | 02:36 AM
911rsq's Avatar
Transmission: yes
JT..... I am not really sure which version of IE I am using. I go to properties and it doesn't really say anything about which version it is. Also, I don't know which service pack I am using of XP. This has to be related to the site itself as everything worked fine before the "crash" and now nothing works. I have heard it from several other people with the same problem. I sent Dirk an email, but he must be busy as he has not replied yet.
Old Mar 28, 2005 | 03:04 AM
JT's Avatar
JT
To find out about the service pack, you can right-click on My Computer and select properties. You should see Microsoft Windows XP. If you have Service Pack 2, it will show that listed as well.
To determine your IE version, in an IE browser window, you can click on Help and then About. It should show the version.
You are right, i have suspected it is a site issue, as your PC is uploading the image to the TGO database, and really, the vB software is responsible for proper linking. But it is quite strange on how many users have no issues (like myself), while only certain users do. i fairly familiar with vB and know that user groups exist and such, but that does not seem to apply for something like this.
Attached Thumbnails Attached Pics come up as a Link, not a PIC??-106-0676_img.jpg
Old Mar 28, 2005 | 03:07 AM
911rsq's Avatar
Transmission: yes
JT....... Service pack 2 for XP and for IE 6.0.2900.2180.xpsp_sp2_rtm.040803-2158 .....that seems like a lot....
Old Mar 30, 2005 | 09:10 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
In the past few days, images I've tried to upload also were posted a links, not images. Perhaps it's related to the file naming convention... I"m using XP, SP2, updated OS and MS IE.
My sig image is linked from my website and displays ok, but I'll try a test image of my son with his '92 Z-28 during our trip through Death Valley as an upload from my computer...
Attached Thumbnails Attached Pics come up as a Link, not a PIC??-c-documents-settings-duck
Old Mar 30, 2005 | 09:23 AM
Duck's Avatar
Engine: 5.7
Now I'll try to upload a file with spaces in the name, just to check those types of filenames are accepted by the site software.
Kingman Route66 Z-28 72.jpg -- uploaded and displayed fine! All is good, at least for me, at this time, in this message area [grin].
The photo is of my son Martin and I at Mr. D'z classic drive-in on Route 66, Arizona, during our recent 2,000 mile midwest road trip.
Old Mar 30, 2005 | 10:20 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I too recently had this same problem. I ended up hosting the pic to get it to show. The next day I was able to post a pic normally without any IE or windows updates.
Old Mar 30, 2005 | 12:19 PM
DJP87Z28's Avatar
lets see if it works......Tried and it still not working right.
Old Mar 31, 2005 | 01:36 AM
onebinky's Avatar
I've been having the same issues. Half the time it will work right, and half the time it will just post the link.
Windows XP service pack 2, IE version 6
Old Mar 31, 2005 | 06:32 AM
DJP87Z28's Avatar
I came to the conclusion that it is a site problem, bcause I can post attachments from the same file with NO PROBLEMS. Nothings changed on my end and been using XP2 all the time with all the updates.
Old Mar 31, 2005 | 12:04 PM
onebinky's Avatar
I just downloaded firefox, and I can attach pics ok now. I don't know if it's because of firefox or TGO though.
Old Mar 31, 2005 | 11:39 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by 911rsq
IRedDevil...u said this used to happen to you.... any ideas on why it stopped doing it????
I actually switched IE versions. I also started using Firefox. I can't seem to stick with one or the other. :shrug:
Old Apr 3, 2005 | 03:26 AM
911rsq's Avatar
Transmission: yes
hmmmmmm
Old Apr 3, 2005 | 03:27 AM
911rsq's Avatar
Transmission: yes
Nope....still doing it...
How do you change versions of IE ??? Maybe that will work for me!!
Old Apr 3, 2005 | 10:44 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I have the same problem what can we do?
Old Apr 4, 2005 | 05:42 AM
911rsq's Avatar
Transmission: yes
I sent Dirk an email....no replys..... HELP US DIRK
Old Apr 4, 2005 | 09:14 AM
JT's Avatar
JT
i'd imagine that Dirk has been very busy getting the new server ready to take over. Since that affects everyone here, and was likely his original plan, i'm guessing he is trying to get the new server transfer taken care of, first. So you may have to wait it out for a little while.
Old Apr 4, 2005 | 07:15 PM
911rsq's Avatar
Transmission: yes
no complaints here... i have nothing but respect for him... just stating a fact that I had sent him one
Old Apr 4, 2005 | 07:52 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
I was running an older version and upgraded to the newer one.
Have you tried out firefox yet? It's really rather good.Hell of a lot fewer pop-ups and malware problems... until it gets -really- popular anyway.
Old Apr 5, 2005 | 12:05 AM
onebinky's Avatar
I like it alot so far. It also seems to load pages faster too, maybe I had spyware that my detectors didn't detect...
Old Apr 6, 2005 | 11:58 PM
911rsq's Avatar
Transmission: yes
I haven't tried FireFox as of yet, but I checked and the version of IE that I am running is the most current....
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
project89
Sep 24, 2015 06:38 AM
Trickskier
Aug 29, 2015 01:12 PM
BurlyChev
Aug 22, 2015 01:52 PM
