E-85 / alternative fuels board
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: E-85 / alternative fuels board
I think you mean 70% of the heating value of gasoline. The thermal efficiency is a function of the engine characteristics,,, not the fuel. Bottom line is, it takes more ethanol to make the same amount of heat as gasoline. This is not all a bad thing though.
The reason gasoline isn't as efficient as diesel is because the compression ratio you can run is limited by the auto ignition temperature of gasoline. Thermal efficiency is directly related to the compression ratio your engine runs at. So, yes, ethanol takes more fuel to make the same amount of heat, but since ethanol also has a much higher octane number (higher auto ignition temperature), you can raise the compression ratio much higher than if you were running gasoline. This can raise the thermal efficiency of burning ethanol to higher than that of burning gasoline.
Fuel efficiency of OF AN ENGINE is governed by two things,,, how much energy is in the fuel (heating value), and how effectively you turn that energy into mechanical power (thermal efficiency).
If you build a dedicated engine (not flex-fuel) to run on ethanol with a higher compression ratio that takes advantage of the 105 octane of E85, then you can get similar fuel efficiency with ethanol even though the heating value is lower, because the thermal efficiency of the engine is higher.
Yes, thats what I meant. Been doing a lot of reading on e85 lately. If they produce a few stations locally, and the price is at least a hair cheaper than regular I'll probably run it in my vette. I'm running 10:1 c/r right now (9:1 dynamic) , and figure eith e85 I could probably get away with a point to a point and a half higher and make more power.
-- Joe
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
