Site Performance
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Site Performance
is it just me or has this sites speed and performance seriously degraded ever since the new move?
Initially, there was performance issues when TGO moved servers, despite the fact that the 'new' server was an upgrade over the 'old' server, hardware wise.
The issue, or a majority of it, was traced down to table locking in mysql, by Jason.
Since Jason took steps to help deal with the above, I have not noticed much performance issues since. The server load may spike on occasion, which is normal, but I have not seen it anywhere near as bad as it was when TGO first was placed on this server and the search feature would bring down the server.
Not long ago, the server even received an extra memory upgrade on top of it:
https://www.thirdgen.org/minor-downtime
Originally Posted by AaronIROCZ
Well as of right now it seems very slow, sometimes it takes 30 sec. to load up a page.
Perhaps you have a connection problem, your ISP or backbone to thirdgen.org
Car: 1988 IROC-Z Convertible
Engine: 305 LB9
Transmission: MK6 5-speed
Axle/Gears: G80, G92, GM3
I came to this board to see if there were any posts from anyone else having posts load slow and found this thread. I have to agree with 86Z and AaronIROCZ it is noticably slower. I am on a dialup and don't expect blinding speed but 20 - 40 seconds to load a post without any photos is typical.
Chuck
Chuck
With as many members as there are on TGO, along with the different ISPs, backbones, and any network issues, there is bound to be some people who have some issues that are not within TGO's control.
I've been on the forums often today and I still have not seen any performance issue at all on TGO. The server load is low, and tracerts to the server show very good results. When I've uploaded or download to the server using FTP, results have been good, too.
Chuck
Chuck
*EDIT* I've timed the last 10-15 threads entered and it has taken @15 seconds to load most but longer with several pictures.*END EDIT*
My anti-virus service blocks pop-ups, etc (I see very few of the ads on this computer but I do on other computers). Could that have something to do with the recent slowness?
jms
Originally Posted by jms
I'm on DSL (100mbps) and I am having 20-30 second page loads the past few days.
jms
jms
There are no pop ups (in the form of ads) on this site. Sounds like you either have spyware, a virus, or other malware.
The forum has not been nearly that slow for me.
Car: Pair of 92 Z28s
Ive noticed a glitch here or there. But now its becoming quite frequent that i get long loading times and/or page cannot be found. Every other site ive gone to i have not had a problem.
Not sure if it is related, but Jason enabled boolean searches this late evening. Since then, even I have had difficulty with server response on the forums. Prior to that, I had not noticed much performance issues, outside of a few glitches.
Axle/Gears: 9-bolt/3.45
I came here looking to post about slow site speeds, too, and here you all are. So I guess it's not just me.
I thought my computer might have some "bugs," even though I've got active anti-spyware protection and an excellent anti-virus program, so I ran full-system scans twice(once while in safe mode, just to be sure), but everything's clean, and TGO is still running at a snail's pace. I'm having no issues with any other site I've logged onto... just TGO.
Car: 89 RS Convertible
Engine: 350 Carbed, No Computer
I have noticed that since yesterday afternoon that trying to open up threads in the message boards is taking about 5 minutes or so and that any of the gif's or images are not showing up. I have tried from 3 different systems at different locations and still have the same problem. Has anybody else seen this?
I did some checking with the LAN/WAN guys at my company about the problem that I have been experiencing. It looks like it has to do with the fact that the site is now using port 8080. That port is blocked at a lot of companies because it is a proxy port from what they are telling me. This could be the cause of some of the problems people are experiencing.
Originally Posted by JT
Initially, there was performance issues when TGO moved servers, despite the fact that the 'new' server was an upgrade over the 'old' server, hardware wise.[/url]
Originally Posted by Zerstörer
The older server seemed much faster then this one. Could you post specs of both servers for comparision? Someone said the old one was AMD. Sure hope you not using intel now.
Jason posted the following specs for the current server:
Dual 2.8GHz Xeon Processors (800MHz FSB) w/ HT
2GB of DDR2-400 RAM
(3) 73GB 10K RPM SCSI Drives in RAID 5
Red Hat Enterprise Linux 3
MySQL 4.1.18 (upgraded from the RHEL3-supported 3.23.58 with the official MySQL-supplied RPMs )
Apache 2.0.46-56 (official RHEL3 build)
PHP 4.3.2-26 (official RHEL3 build)
2GB of DDR2-400 RAM
if your company is blocking traffic on port 8080 (or any other port) then you might want to think about the reasons why they are doing it. The only reason I can think of is that they want you to actually do work, not surf a forum site.
When I experienced my run in with it being slow I was at my parents house. Now when I am at home it is running great. My parents connection t1 while mine at home is cable. So I beleive that my case was my internet connection. Sorry to complain to you when it was my problem the whole time. Hope this helps.
I was on the forums when Aaron was also on the forums and posted about slow speeds. The forums were operating normally for me. I ran a few tests to the IP address he was posting from, to see if there was an obvious network issue near his end due to the fact things were OK for me. I seen some packet loss near his local end. That would cause performance issues.
Originally Posted by Jason|Xoxide
Images are fed from a separate server so Apache doesn't have to spawn a 30MB process to serve a 20K file.
In addition to being used by some proxy servers, port 8080 is also used as a common port for web servers. In fact, it is normally listed as "http-alt". Tomcat, for one, is set to a default of port 8080 as it is generally run beside Apache. Any server spawned by a user other than 'root' would also probably default to that port (as only 'root' can open that port).
Car: 1986 Camaro SC
well before thirdgen.org was moved it was fast always, the site is slow now, sometimes icons dont load, and last night early this morning 4/26 thirdgen.org was not found. was the site down for some reason? i dunno what it is but for me performance has gone done a lot, i visit this site every day it's a great site, it has a lot of information, i've donated, and will continue to do so, but sometimes it's just unbarable
Engine: 305 LB9
I just noticed something interesting. When I came onto the boards this evening I was not logged in and was viewing them as a guest. The posts loaded fast - really fast. I then logged in and things noticably slowed down. It again took 20-30 seconds to load a post.
I logged on and off of the site several times trying to open posts in each situation. When ever I was logged off and was a guest posts loaded very fast. However, each time I logged on things again got slow as molasses. Coincidence???????
Chuck
Chuck
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Ive also noticed that sometimes (even during the morning and mid day) that it can take quite some time to load pages.
Maybe its time to outfit the server with an intercooled turbo and 500 shot
Or clock that baby up and rig up some Ln2 cooling...
Car: 1986 Camaro SC
We can't find "thirdgen.org"
You can try again by typing the URL in the address bar above.
Or, search the Web:
Go to MSN Search to see complete results for "thirdgen.org".
Popular Searches
Did you intend to go to one of these similar Web addresses?
www.thirdgen.org
You can also visit one of these related Web sites.
Firebird - Third Generation F-Bodies
Check availability or register the domain name 'thirdgen.org'.
More information about this error.
About Results
• Not satisfied with your results? Help us improve.
Powered by MSN Search
©2005 Microsoft Corporation. All rights reserved. Terms of Use TRUSTe Approved Privacy Statement
no.... this site is not slow, before the site was sold or changed servers it was fast and not a hiccup or problem.
Or, search the Web:
Popular Searches
www.thirdgen.org
About Results
UltRoadWarrior9
Apr 28, 2020 10:39 PM
