this site is slooooooow! WHat happened?
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
This site is running so slow that I am typing faster than the letters can appear on the screen. It is so bad I cant read the forums, the screens take too long to come up. No problems with any other sites. Did teh server get downgraded? This started weeks ago, I have just about given up on trying to look at the board.
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
I'm having the same problem... i got cable 8000 down 512 up Pentium 4 HT 2.8 GHz 80gb harddrive Asus Motherboard.. Very fast
How much memory do you have? I'm using a 2.8 P4 as well, with only 512MB RAM, and I don't experience that issue with these system specifications.
Car: 1990 Camaro RS
Axle/Gears: 3.08
Amazingly its not doing it to me "Right" now but it was this afternoon and occasionally when i'm surfing this site. I check around this site quite often for new updates and threads and things... I have 512 DDR
Car: way too many
I have 1 gig memory.AMD processor overclocked to 2+ GHZ...just rebooted the computer and it seems to be working better now, but I have to wonder why if my memory is somehow getting taxed why every other site I go to works fine? I mean I could type a sentence and literally sit there 30 seconds until the words would appear on the screen..never had that problem with this site before, why all of the sudden now?
We are in the process of making some minor adjustments to the site. There is not much we can do without applying changes directly to the site and to see how the changes react to the amount of traffic this site gets.
If there is hangups with the system we tend to notice them right away and make the changes neccessary to fix the problem to the best of our knowledge.
Car: 88' Iroc-Z
Engine: LQ9
i've noticed it taking awhile to load alot of threads and sub forums. I've got the same internet 8mb down 512kb up with a 3.2ghz amd processor with 1.5gb ddr400. So I know it's not on my end I was guessing my isp or the boards. But seems like all other sites load up fine. It is alot better today than it has been the past few days.
Car: 2001 Grand Prix GT
Engine: 231 NA
Transmission: 4t65e
and here I thought it was only me. I love browsing this board for info, but a man can get ulsers when a site is this slow. I dont know how I did it back then with dialup...
Car: way too many
Still happening..CPU usage just about maxes out while trying to surf this site...doesnt happen anywhere else. Has to be something here, never used to do this before the takeover.
I know this is not a "fix", but if you try FireFox, I think the issue will disappear. I'm not a FireFox fan boy, but if you want something that will work *right now* to better alleviate the issue, you might try FireFox.
Car: way too many
thanks but I dont want to switch browsers for just one sight. I just dont come to the site now unless I have to. I assume this is happening to all AOL users if it is a browser issue, so site traffic must be down.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i deleted my response above.,
deleted due to the fact no one really seems to know why its happening and so therefore everyone has their own opinion/belief of why it is happening and wont accept any other explanation from anyone
sigh,.,.
such is one of the troubles with mankind
good luck
fyi- its sure funny how other sites are loading up fine as usual/always- no pages loading lag experienced,
well except for myspace.com of course, lol
good luck......,.,.,
sigh,.,.
good luck
Originally Posted by Fast68
yeah its traffic volume that doesit
more users ar a given time = more bandwidth useage = potentionally lagging server(s) which in turn makes for slower page loading times
common problem on the internet
nothing ot be worried about it happens all the time and even to ALOT worse degree on places such as myspace and so forth where VERy heavy traffic is seen some parts of each day especially in the evening times, evne last night pages werent loading up
it happens
if pages are lagigng bad for you then the only real thing you cna do is simply wait til a bit later to come back and surf a given site that is experiencing the heavy traffic
trying ot reload pages that arent loading up will only make the problme worse and the bandwidth useage increase,
if i am wrong/incorrect about any of this then id like to know
good luck
it happens
good luck
However, yesterday, we did have some server load issues that caused intermittent periods of general slowness while accessing the forums. However, it is a different issue than what the original poster's issue is.
Engine: 4.3L Z TBI
i dont see how it has nothing to do with it
he said its slow
bandwidth speed and everything has plenty to do with page loadin speeds
i supposed we just misunderstand each other
hum
ill just delete my reply up there and save all the trouble
sigh...
but anyways what things do you think could be causing this one:
the site has been real laggy lately for sure. seems ot be getting worse, but at least it only lasts for a small amount of time, but its often
especially in the evenings and nights,
good luck
he said its slow
hum
sigh...
It is because something is causing their CPU to nearly max out, causing their browser to perform sluggish. This has nothing to do with bandwidth.
good luck
He stated the following:
When I asked about his CPU usage, as I suspected it was being "hammered", he then stated:
I have also experienced this issue on an older machine running IE, where the cpu is at 100%, and when switching to FireFox, this particular issue was then gone.
This particular case with text not appearing while typing does not appear to be due to any common "internet" issues involving bandwidth speed or latency.
There has been some intermittent periods of time in the past couple days where we've had some higher than normal server load, which causes some longer than normal delays. That might be what others are referring too, but that is not related to this particular issue.
Originally Posted by JT
The explanation you provided has nothing to do with the original poster's question, which is where typed text in the text input field does not appear on the screen for a length of time - you watch the text "catch up" after you've typed your text. This problems appears to be prone on older machines running IE. It is because something is causing their CPU to nearly max out, causing their browser to perform sluggish. This has nothing to do with bandwidth.
even with my p2 333mhz/128mb laptop i have the same issue just not as bad.quess its a good exscuse to stay off the boards while im at work though lmao
Originally Posted by daves12secV6
i have this problem only when i use either of my laptops,th eoldest one being a p1 133/32mb ram used to load the site fine and was able to type in the reply box without it lagging and the txt having to catch up.
Another reason why I don't see this as a "bandwidth" issue, is because the issue is still present well after the page has fully loaded and is "done".
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
The administrators need to upgrade thier service. More bandwith is needed to run this HIGH TRAFFIC SERVER. Everyone is right, this is running slow. Keep in mind Admins, that most of the users here are running PENTIUM 3 computers...
Car: 88' Iroc-Z
Engine: LQ9
i've got a fast cpu and running firefox and still have the problem.
the old site wasnt a google ***** either, so that's the differenc ei believe there is alot more traffic than there was before and the server needs upgraded to handle it.
Since you are the ones making this claim, you should be able to back it up, so I will be happy to hear how TGO not having a "high traffic server" (so you say), is what pegs *some* user's CPU usage on their machines, while others are not impacted.
You are also dismissing that there are numerous users on here that are *not* experiencing this issue.
As I mentioned before, there has been a few intermittent times when there has been higher than normal server load (temporary spikes), but that and this issue don't appear related.
By the way, not disputing the "fact" itself, but exactly how do you know as a fact as to what *most* people *here* are running for machines? You don't have a hard fact. You are making a best guess.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
a simple solution would be to remove atleast half of the crappy plug ins that this board is filled with....
it might not help, but it would **** me off less.
