Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
name modification
Old Sep 1, 2007 | 09:51 PM
BOTTLEDZ28's Avatar
Transmission: A4
name modification
is it possible to modify my username? I have BOTTLEDZr28 and I want to remove the r from my name. back in 1999 I registered the name BOTTLEDZ28 but then forgot my password and just re registered with the current name I have now. I would like to have the same username on all the message forums I am a member of. The username of BOTTLEDZ28 will be active on here but there is no post couint on that name. It is mine though and I can verify the email address I used to sign up with it.
Old Sep 1, 2007 | 10:03 PM
JT's Avatar
JT
Community Administrator
Re: name modification
Done.
Old Sep 1, 2007 | 10:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
thanks. would it be possible to keep my itrader number would it? It was 2. If not then thats ok I guess
Old Sep 1, 2007 | 10:12 PM
JT's Avatar
JT
The iTrader number is the same as the user id number. Unless you meant you had 2 feedbacks on the iTrader?
Old Sep 1, 2007 | 10:13 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya I had 2 positve feedbacks on the itrader.
Old Sep 1, 2007 | 10:15 PM
JT's Avatar
JT
I'll send you a PM on this issue.
Old Sep 1, 2007 | 10:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
JT, by having my name changed, this means that I will no longer recieve email notifications from threads I posted to with my old name right?
Old Sep 1, 2007 | 10:43 PM
JT's Avatar
JT
Normally, that is unaffected. Do you not have subscriptions that you once had, as shown in your UserCP panel? You may need to click on the view all link. https://www.thirdgen.org/forums/subs...n&folderid=all
Old Sep 1, 2007 | 10:47 PM
BOTTLEDZ28's Avatar
Transmission: A4
Im relieved. it all looks perfect. so when you chang a name like this, does it change the entire site as well? if someone went into their PMs they would still find my PM I sent them but the name will be changed on their end as well?
Old Sep 1, 2007 | 10:52 PM
JT's Avatar
JT
That is correct. It is applied across the forum. The old username is replaced with the new username.
Old Sep 1, 2007 | 10:53 PM
BOTTLEDZ28's Avatar
Transmission: A4
ok thats great. So, did I loose the itrader feedbacks
Hotrodboba400
Dec 10, 2019 07:07 PM
slowsi
Oct 18, 2015 08:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
