Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Thirdgen.org is running terribly slow
Old Apr 13, 2008 | 01:08 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
For the last 3 months I've been having a real problem trying to log onto the site. I takes about 5-10 minutes between clicks to get the page to come up. I have high speed internet and don't have this problem with any other website. Please help me out and give me some pointers. I'm tired of logging on at camaroz28.com! Thanks
Old Apr 13, 2008 | 01:21 PM
JT's Avatar
JT
Community Administrator
Re: Thirdgen.org is running terribly slow
Taking 5-10 minutes for each page to load? If that was the case for the majority, we'd have a mass of complaints on the forums and via email. We'd also have a sharp loss of activity, too. Neither appears to be the case. I have also not experienced such issue. If this was a server issue, or on the server side, all would be affected.
There are a few things to check, on your side.
1) What browser are you using?
2) Does it appear to be a rendering issue? Does the page take a long time before it appears? Or does it load in stages?
3) What does your CPU usage look like when you're on the forums?
4) Can you post a traceroute to thirdgen.org?
5) Does this issue occur on the forums and main index page (https://www.thirdgen.org) , or just one?
Something to keep in mind is, with the way the Internet is built, just because you do not experience an issue with another website, that does not, by default, make the issue on the other end. In short, the path between you and each server will vary by different backbones and regions.
Old Apr 13, 2008 | 11:39 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I used to have this same problem I found out if I turn off javascript the site works just fine....not sure why though
Old Apr 14, 2008 | 12:33 AM
jeffcj's Avatar
This has to be a browser issue. In the last few days alone I've browsed TGO with IE7/Windows XP, IE6/Windows XP, Firefox/Windows XP, and at the moment, Firefox/Ubuntu Linux.
Maybe a quick scan with Ad-Aware would be helpful.. (http://www.lavasoftusa.com - just get the free version). Try deleting temporary Internet Files (cache) in IE. Just a couple of quick things worth trying.
Old May 28, 2008 | 08:58 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
in my case the worst of the lag is when i go to type a reply out -it takes forever and ever for text to appear
i notice that my iexplore.exe in my task manager has a high K of memory usage
for example, right now it is using 24,660K with only two internet exploder windows open, both of this site
this problme never started until about a year ago or so and it is VERY frustrating
i have tried firefox and opera,
a different computer
formats and reinstalls of windows xp
disabling all addons in the browser
and so on
all to no avail
its crazy
if anyone knows a fix then lemme know
Old Jun 10, 2008 | 06:42 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I too have found that I can type faster than the computer is displaying on this site only. I have to go back over everything I type and add the letters that were dropped by the PC. It does get annoying and I wish I knew what it was.
Old Jun 10, 2008 | 09:05 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i plan on getting a new windows box soon a P4 one and that should take care of the issue
hmm
in a couple weeks or so that is, yay :P
Old Jun 11, 2008 | 10:10 AM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
There is definatly a problem, i connect from work and from home. Work has dual OC-12 setup and home has High speed DSL. maybe its the backbone, however ive havent found it fast in a long time
Old Jun 11, 2008 | 10:20 AM
DCOWBOYS1975's Avatar
Car: 1986 Chevy Silverado
Engine: 350 Crate
Transmission: Turbo 400 w/ shift kit
Axle/Gears: dana60/corp14 4.10 gears
I am on a T-1 line and it flies. Not the site.
Trey
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
pfsteichen
Feb 9, 2016 06:59 PM
86Base
Aug 8, 2015 01:34 PM
