Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
No Reply/PM Notices in 3 days?
Old Aug 14, 2009 | 10:58 AM
Stephen's Avatar
Car: 87 GTA
My Inbox shows nothing from TGO since the 11th.
No Reply notices...No PM notices, nothing.
What's up with that? TGO system problems?
Old Aug 14, 2009 | 12:22 PM
JT's Avatar
JT
Community Administrator
Re: No Reply/PM Notices in 3 days?
Well, I just sent a test email from within vBulletin to two of my accounts and both arrived within 1 minute (and both were not to any thirdgen.org email address).
In addition, you won't get any PM notifications when you have that feature disabled, as your account is showing:
Send Notification Email When a Private Message is Received
is currently set to NO on your account.
And we did not change or alter your account.
Old Aug 14, 2009 | 12:32 PM
Stephen's Avatar
Car: 87 GTA
I didn't change it, so YES....Someone at TGO did.
Old Aug 14, 2009 | 12:35 PM
Stephen's Avatar
Car: 87 GTA
AND...That only applies to PMs.....Doesn't explain why I've gotten not Reply notices of threads, in 3 days.
Even your screen shot says I should, but I don't.
Old Aug 14, 2009 | 12:45 PM
JT's Avatar
JT
I can look at logs (which account changes are logged) to see that no TGO staff has even touched your account since atleast the beginning of this year. So, no, TGO did not change that setting.
As to why I even checked it, well, being in "support" for the past several years I can't assume a lot without checking basics.
As far as the notification issue, it looks like it's isolated to your provider (RR):
<Stephen's email address here@Austin.rr.com>: delivery temporarily suspended: connect to
hrndva-smtpin02.mail.rr.com[71.74.56.244]: server refused to talk to me:
554 5.7.1 - ERROR: Mail refused - <67.201.16.50> - See
http://security.rr.com/cgi-bin/block...p?67.201.16.50
ERROR:5.7.1:550 Mail Refused - NETWORK_OR_IP_GOES_HERE - See http://security.rr.com/mail_blocks.htm#directspam - 200YMMDD
This error message indicates that one or more Road Runner customers complained about unsolicited email that was received from the IP address mentioned in the error message or from the network containing the IP address. The last eight digits of the error message (shown here as 200YMMDD) will indicate the date that the block was put into place. (e.g., 20040815 means the block was put into place on August 15, 2004; 20050228 means February 28, 2005).
We'll have to investigate. Issues like these usually take some time to resolve (usually the other end). In short, according to RR, RR customers have "complained" about "Spam" and thus RR has blocked our email server and that's why you aren't receiving email from us.
It shows the above took place around 8/11, so it nearly syncs with your report.
Old Aug 14, 2009 | 01:23 PM
Stephen's Avatar
Car: 87 GTA
What is the IP address that TGO uses to send messages, that RR would be blocking.
I can get it unblocked, if I know the source IP Address.
Old Aug 14, 2009 | 02:36 PM
JT's Avatar
JT
The IP is in the header there: 67.201.16.50
It's already been submitted. But it doesn't (usually) become unblocked right away. Hence why I said it usually takes time for the provider to process and review it.
Old Aug 14, 2009 | 03:47 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i also have not recieved anything from TGO in several months . i am no computer whiz , just barely know how to use it . no replys , no info from any threads & no P.M.s ????????? what's wrong ????
Old Aug 14, 2009 | 07:30 PM
Stephen's Avatar
Car: 87 GTA
Strangely enough, it came back earlier, as not currently blocked. Nor blocked in '09 at all, much less in the last 3 days.
http://security.rr.com/cgi-bin/block...p=67.201.16.50
Old Aug 14, 2009 | 07:44 PM
Stephen's Avatar
Car: 87 GTA
Check with your internet provider & see if they are blocking TGOs emails.
Old Aug 14, 2009 | 07:54 PM
JT's Avatar
JT
It was showing blocked under the "Road Runner Internal IP Address-Based Block", which now shows no blocking. The prior history section is still the same, so perhaps they have not updated the database? It was blocked, as the emails I posted indicated and their system shown as such at the time with a start date of 20090811. We sent a submission to unblock. Some cases take longer than others.
I have been monitoring this and have not shown any bounce backs, as of yet. I can only suggest that it may be going into a Spam/Bulk folder (for some reason out of the blue), or perhaps emails are disappearing when sent to your provider.
Old Aug 14, 2009 | 08:01 PM
Stephen's Avatar
Car: 87 GTA
It is now unblocked. I went round & round with them today, including getting ahold of a Stupidvisor & pursuing "other" channels (got it fixed that way) within Time Warner.
Nothing was going into Spam/Bulk. Just not being delivered. Maybe they don't waste their effort on replying to blocks?
About 20 notices just came in, from today. Half of which I had already found by looking through the "New Posts" page.
Old Aug 14, 2009 | 08:32 PM
JT's Avatar
JT
As suspected, the history wasn't updated on RR's mail page as now the webpage is showing the block existed and was removed today:
Stephen, your issue with RR may be different than UNCLE TOM's. He's using a different provider (Juno) and we're not receiving any bounce back notices - unlike with RR where we received some bounce back notices. UNCLE TOM's emails may, suddenly, be going into a Spam/Bulk folder. They aren't being returned to us with any notice of any failure. So they are either going through, and into a Spam/Bulk folder, or Juno is just zapping them on the spot. I'm not seeing email delivery failures for Juno at this time. Some providers, like AOL, have been known to just delete email they deem as Spam without any notification to the receiver or sender.
As this case with RR illustrates, providers can handle email different and customers can have an affect on what is, or is not, delivered or how it's delivered.
Old Aug 14, 2009 | 09:23 PM
Stephen's Avatar
Car: 87 GTA
200+ Reply Notices later.....Hopefully they'll stop & give my eyes a rest. My head hurts. Too much reading for the last few hours!
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
Ranbo108
Sep 9, 2015 12:20 PM
tgp1990
Sep 4, 2015 06:24 AM
andy74
Sep 3, 2015 08:41 AM
