Hooker LS turbo manifold build
Old Jan 19, 2018 | 01:01 PM
89FormulaLS's Avatar
After buying and installing the cx racing ls thirdgen kit I realized the amount of tubing and 3" hotside were not ideal for an s480 that I planned to install... Switched to hooker LS manifolds and fabricated up the hotside, and used the cx racing coldside that comes with thier kit as the intercooler has a great core and it was all 3" piping.
Here are some pictures to give you guys an idea of how I did my kit, with the thirdgen there isnt a lot of room for the turbo to be up very high. I ended up using mostly a 3" 304 ss donut and hacked it up.... Flange is an open t6 from ebay with cnc transition.
VS racing 60mm wastegate and S480 96/88 1.32ar. Setup should be good for 800 tire and mid 4000 full spool. I also re did my fuel system, tucked the regulator up in the cowl and ran lines through the fender well... Not pictured but I did make a shield that covers the lines in the fender from rocks and debris.
The whole front end of the car is hacked up because I will be doing tubular shock towers and front bars when I start installing the cage... the rest of the radiator support will be cut out and the rad/intercooler will be all mounted to 1" and 1 5/8" tubes
Old Jan 19, 2018 | 09:57 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Hooker LS turbo manifold build
Wicked man!! How do those manifolds fit?? Does the cross over pipe fit good to? I'm kinda wanting to get the same thing for my 91. Are you doing a 5" DP or a 4"?
Old Jan 20, 2018 | 05:40 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
How does downpipe clearance look if you wanted to exit to the stock location without cutting anything? And with the AC box in place. Any room by cyl #8?
Old Jan 20, 2018 | 05:34 PM
Out doing some street tubing today. Things a tire burning monster. Spools as soon as it gets up on the converter
Old Jan 20, 2018 | 07:53 PM
thatsupnow's Avatar
Is that a 6.0l your using or a 4.8/5.3??
Old Jan 21, 2018 | 10:25 AM
You won’t have room to run the downpipe back down on the passengers side above the manifold. It’s a little too tight back there. Car is a 5.3, downpipe is 4”, I would have done 5” but the turbo came with the reducer flange, my exhaust is about 1.75’ long so doesn’t really matter
Old Jan 21, 2018 | 11:38 PM
wildmon69's Avatar
Car: 86 T/A/1990 Firebird
Engine: 5.3 L33 pt7675 / Ls1
Transmission: 4L80E/T56
Axle/Gears: 3.73/4.10
Thank you 89FormulaLS! I have been watching the forums closely waiting to see if any one has tried this manifold setup. And Finally at last someone has tried it!!! First off, YOUR BUILD ROCKS. I was going to run the stamdard truck intake but you've proven the tbss intake will work nicely I will likely be plumbing my fuel system very similarly to the way you posted in the other cx racing instal thread created by battmann. Much cheaper then getting a 4th gen tank and messing around with that. One thing I was wondering about is what crossover pipe you bought because Holley sells a few different ones. Or did you fab that one up yourself?
Old Jan 22, 2018 | 11:43 AM
scooter's Avatar
I am interested to know what that water outlet is on the water pump and part number
Old Jan 22, 2018 | 04:39 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Thanks for the info.. Does your exhaust turn out and dump behind the front tire? Always a challenge to run a downpipe on these cars.
Old Jan 22, 2018 | 07:52 PM
I’m running their crossover, I have a turbo 400, they make one specific for the th400
Yep it just dumps about 1/4” into the fender
Old Jan 22, 2018 | 08:11 PM
wildmon69's Avatar
Ok cool thank you, I'm running the 4l80 hopefully that one fits too.
Old Jan 23, 2018 | 04:22 PM
wildmon69's Avatar
89Formula, do you think the downpipe could be run in the stock location IF the A/C box was not used?
Old Jan 23, 2018 | 07:36 PM
I dont have an ac box and no way you could fit even a 2" pipe down there unless you chopped up the firewall
Old Jan 23, 2018 | 09:10 PM
wildmon69's Avatar
Could you possibly get a picrure of how close it is to the tire. I want to use this similar setup as a daily driver and I'm wondering if it will heat up the tire. Also do you think theres any way that the pipe could be continued to run under the car?
Old Jan 23, 2018 | 11:28 PM
no problem, Ill post up a few pictures tomorrow. Ive got skinnies on the front but have some stock wheels I need to put back on.
Old Jan 25, 2018 | 04:18 PM
Whelp my garage has turned into a fab shop. Started on cage and front end.
Some me pictures of turbo, exhaust and room behind
Old Jan 25, 2018 | 04:48 PM
I'm interested to know about your throttle cable. The throttle cable is obviously aftermarket but how it attaches to the firewall looks like you used the stock mount. Did you use the stock mount and cabin sleeve along with the stock clip and then use an aftermarket braided cable setup?
Old Jan 25, 2018 | 10:29 PM
That’s exactly what I did, it’s the lokar cable hawks sells. I was pretty pissed when I got it and realized it’s just a generic throttle cable.... not thirdgen ls swap specific
Old Jan 26, 2018 | 09:59 AM
Good to know, thank you for the reply. Sounds like we were both in a similar predicament.
Old Feb 4, 2018 | 11:46 PM
Cage about done, should have this thing on the rollers next weekend. Will post up numbers if everything goes well!
Old Feb 8, 2018 | 11:09 PM
wildmon69's Avatar
It looks like its coming along nicely. That cage looks solid, those gusset plates around the tunnel look beefy as heck.
Old Feb 10, 2018 | 03:52 PM
cage and front end halfway done, going to start rewiring everything now and installing a 4th gen dash. I need to build a tubular radiator/intercooler support with some mounts for the pop up headlights.... and front bumper attachment brackets..... fitted the hoop as possibly high as I could, can slip about 5 pieces of paper inbetween it and the ttops, at 6'1 I need all the room I can get
Old Mar 31, 2019 | 08:54 AM
TJFormula350's Avatar
Car: '87 Pontiac Firebird Formula 350
Engine: 5.3L SBE LM7
Transmission: TH350
Axle/Gears: 3.47:1 Stock axle
Any updates on this build? It looks to by almost exactly what I'm doing with my Formula350.
Old Oct 17, 2020 | 01:09 AM
JAYDUBB's Avatar
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Yeah, any updates? I'm close to pulling the trigger on something similar...
Old Oct 19, 2020 | 08:48 PM
thatsupnow's Avatar
They fit perfectly. I've got a set on my 91
Old Oct 8, 2023 | 10:08 AM
Swatguy1870's Avatar
Car: '86 IROC Z
Hey man. Older thread I know but….. what motor mounts did you use? Both on the engine and on the K member. My passenger side manifold is hitting the the factory mount on the K member. I have dirty dingo swap mounts on the engine. Looks like I need to raise the engine about an inch or change the factory mounts on the k member. Thanks.
Shinobi'sZ
Aug 23, 2017 09:44 AM
86transamws6
Apr 21, 2003 03:58 AM
RoadRocket L98
Apr 25, 2001 06:22 PM
