Anyone know off vatts in 88 formulas
Old Apr 29, 2018 | 07:56 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Was told some members have vatts in there 88 gta's. Got my formula with the key broke off in the ignition switch. Anyone?
Old Apr 29, 2018 | 07:58 PM
Community Influencer
Re: Anyone know off vatts in 88 formulas
Some have vats in 88, if you post the letters on the memcal or prom I can see if I have the file to check to see if it has vats . If it’s tbi it wouldn’t have vats some tpi did. Another way to tell is if there is a blue wire in pin b6 of the ecm if it’s tpi.
Old Apr 29, 2018 | 08:20 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
its factory 350tpi roller. Does the non vatts have the small white wire on the lower column. I will look to see if the ECM is even in it
Old Apr 29, 2018 | 08:23 PM
If it has the white wire it should have vats.
I think there are two wires in a orange sheath at the bottom of the column
https://www.thirdgen.org/forums/elec...pass-vats.html
Old Apr 29, 2018 | 08:44 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
ECM long gone. To the far left there are two white connected to one white and one orange.they look a little big. On column there's a black sheath wire with 2connectors with about 4 wires leading off them. I have had some cars with vatts and don't see any wires like I had in them
Old Apr 29, 2018 | 08:45 PM
If the ecm is gone why are you worried about vats ?
Old Apr 29, 2018 | 08:53 PM
That's a awesome thread. Should be a sticky.
Old Apr 29, 2018 | 08:54 PM
should be call a moderator
Old Apr 29, 2018 | 09:10 PM
I did a while ago. JT never responded.
Old Apr 29, 2018 | 09:14 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
gota change out messed up ignition switch at a minimum. Po broke the key off in it. They damaged the plastic ring at the base where it meets the dash
Old Apr 29, 2018 | 09:24 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Oops
Old Apr 29, 2018 | 09:25 PM
I didn’t get a response either
Old Apr 29, 2018 | 09:27 PM
If your going carb you don’t have to worry about it. If you do find the leads you can ohm them to see the stuck keys resistance.
You can buy the matching key and cylinder on eBay.
Old Apr 29, 2018 | 10:09 PM
JT's Avatar
JT
Community Administrator
To answer the history question, 1988 GTAs, but apparently not all, received the VATS. Formula and Trans Am was not part of this until 1989.
Here's a good Pontiac Distribution Bulletin from GTASourcepage about that:
John's website also notes VATS coming to the Formula in 1989:
http://www.3rdgenformula.com/89/89_history.htm
Old Apr 29, 2018 | 10:54 PM
George Klass's Avatar
Car: 1989 Trans Am
I tried to use a non VATS ignition lock on my 89 and it didn't fit properly. It was too short and would also not turn back into accessory.
fryboyswagg
Mar 2, 2015 10:10 PM
PLANT PROTECTION
Oct 9, 2002 11:53 PM
firebird305
Theoretical and Street Racing
Nov 25, 2001 01:15 AM
matt_at_ttu
May 16, 2001 10:06 AM
