New "Astro" Steering Bearing / Upgrade...
I am posting a link, for reference, I am not the seller, nor getting any kick backs... just a thirdgen user wanting to spread the word...
If you've been looking through the classifieds (like I do) you've seen a couple of sellers that sell an upgraded Astro Steering Shaft... it basically replaces the sloppy / worn rag joint with a metal U joint... Nice...
Another upgrade some were doing, they were upgrading the lower factory plastic bushing with a bearing that the Astro van's also had... most people I talked to said they had trouble finding one in good shape... and I really wanted to address all the upgrades here...
I checked ebay and found a seller... I emailed him first and explained that the 91 Firebird had a plastic bushing, would this actual bearing fit / work? He stated yes. So I ordered it. And it does nicely!
It does state in his ad, "non air bag" but my 91 had an air bag, and it fit fine...
I bought the one from ebay, seller cjsrods73j3, currently $45 shipped...
Part # 69-95GM
Item Title: 69-95 GM tilt & non tilt New Steering Column Lower Bearing, 100% USA Made, L@@@K
Current Ebay Auction
http://www.ebay.com/itm/69-95-GM-tilt-non-tilt-New-Steering-Column-Lower-Bearing-100-USA-Made-L-K-/131481158788?vxp=mtr
There are a couple sellers here in the classifieds selling the shafts, so if you want to also upgrade the plastic bushing to a bearing, this one works...
The steering is tight after upgrading these 2 items!
Rafael
Part # 69-95GM
Rafael
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: New "Astro" Steering Bearing / Upgrade...
Just ordered one to go with the new shaft. Nice find.
Car: 1984 Camaro Berlinetta
Axle/Gears: Australian 9 bolt 3.27 posi
I got me an Astro steering shaft but was unaware of the lower bearing. Was it difficult to remove the plastic one and put the new one in? Here's my shaft..hehe
Oh btw my car is an 84 berlinetta with tilt sterring.
Right on, I am not mechanically inclined.....and disabled that's why I ask how difficult it is. Also my car has tilt steering, does that mean I cannot use it? It may as it wasn't supposed to work for air bag and it has. What do you think luvofjah?
Awesome, thanks man. Does it come with instructions? or is just a matter of removing the retainer clip then it all come out? Also appears they will not ship to Canada. I emailed the seller and asked if he would send to Canada and now I wait.
Thanks for clarifying that for me 84 1LE. Appreciate it.
I just ordered my bearing kit......came out to $79.91 CAD. The 19 dollhairs for shipping didn't help...oh well...steering is gonna be nice!
Got my new Steering Column Lower Bearing, this will go nicely with my new Black steering shaft.
Hi!
Does anyone still sell them? cjsrods73j3 did not sell anything since a year..
Thanks!
Thanks!
i did at first.. but didn't found them. Only from the newer astro versions.
The two above, look like just the bearing. These look like them, gotta shop around, is all.You want the whole assembly pictured. Still, i would pay the JY a visit and score one from an astro van. Cheaper still.
https://www.ebay.com/itm/35258809855...75.c101224.m-1
https://www.ebay.com/itm/15373588591....c101113.m2108
https://www.ebay.com/itm/40052182398...75.c101224.m-1
BOOT77 (03-02-2022)
We have them available at the link below:
1982-92 Camaro/Firebird Upgraded Steering Column Bearing Kit (screamingchicken.com)
J.C. Denton (03-04-2022)
Summit has the jeep one for cheaper and one of the reviews said it worked on a chevy square body truck https://www.summitracing.com/parts/o...RoCV68QAvD_BwE
Dang just ordered some junk from Summit too!
Same here, I just replaced the steering shaft and steering box on my '91 about 6 months before we started selling these. I installed one on my '83 but it isn't drivable yet, really seemed to improve steering feel sitting still thou.
Axle/Gears: 9-bolt/3.45
This thread began about 8 years ago, was last revived about 1 year ago, and I'm reviving it again now to describe a common problem with these bearings that most people probably have but don't know it, causing the bearing to function improperly, even though it might seem like it's functioning properly. Clear as mud? Good. And if people purchased these bearings in 4 pieces that need assembling, like it's commonly sold, then there's a good chance yours might be defective, and you probably don't know it.
Initially purchased mine from a vendor, who I won't name, because it's not the vendor's fault, and it came in 4 pieces to be assembled, which tends to be common from most vendors. After I assembled it, I noticed something that couldn't possibly be right, so I searched the net and found a video on YT by user, Suburban Ranch, where he addresses the problem, shows it in detail, he linked a steering business that confirmed it as a common defect, and he got a bearing from them that functions properly. So I contacted them, and I also purchased a properly functioning bearing.
gm, buick, cadillac, chevrolet, oldsmobile, & pontiac steering column housings and bearings 7805700 Brgkit60 lower bearing kit | Steering Column Services
My 37 year old original factory bushing was still solid, smooth and perfect with no slop whatsoever, so when I encountered the problem with the bearing, I almost didn't bother looking for a correctly made bearing. But since I had it all apart, it was now or never, so I did the search and found the problem and the answer.
When you snap the bearing assembly into the white bushing, the bearing race is supposed to fit so tightly that it will not move/spin inside the bushing. Yet it's common for the entire bearing assembly to spin inside the bushing, race and all, which defeats the point of having a bearing. No way that could be right, and it's not. The bushing and bearing race are supposed to be rock solid tight together, so that only the inner bearings that grip the column turns as the column turns. If your entire bearing assembly, race and all, is turning inside the bushing, then yours is defective.
What Steering Column Services will do, if you mention the situation, is preassemble the bearing assembly into the white bushing to confirm that the bearing race is tight and secure in the bushing and doesn't move, that only the inner bearing turns in the race, and then they'll ship it to you like that.
The problem lies in the manufacturing process of the white bushings. Sometimes they'll shrink ever so slightly immediately after the manufacturing process, leaving the inner surface of the bushing a hair too large for the bearing assembly, so that when the bearing assembly is installed into the bushing, the entire assembly is loose and spins inside the bushing, which it's not supposed to do. So if any of you found that the bearing assembly popped into the bushing easily, then it's probably loose in there, and it shouldn't be. The bearing assembly should be a ***** to install into the bushing, so that the only thing that spins is the inner bearings in the race, not the entire bearing assembly.
The entire assembly spinning in the bushing will probably be slightly "clunky" and could become "clunkier" as the bushing wears due to the looseness of the bearing assembly in it. It's something you might not notice during driving, early on, but if you were to grab the column and try to move it up and down, you'll probably be able to very slightly, but enough to feel and hear it lightly "clunk." But that's not supposed to happen; you shouldn't be able to move it. I suspect most of you popped the bearing assembly into the bushing, may or may not have noticed a slightly loose fit, but thought it was good to go, and away you went, with everything seeming to be working fine, when it really wasn't fine.
I'd suggest y'all pop your hoods, start the car, have someone turn the wheels back and forth, while you watch the bearing carefully. If the entire assembly is turning inside the bushing, not just the inner bearings, which won't be easy to see with everything installed, then the white bushing is defective. Or for those of you who have the new bearing but haven't installed it yet, pop that bearing assembly into the white bushing, and if the entire bearing assembly spins in the bushing, not just the inner bearings, then yours is defective, and it'll be good that you learned that now before installing it. If so, then I'd suggest you return it to where you purchased it and contact Steering Column Services for one that's preassembled and confirmed tight.
Man, that was long! And probably very redundant. But I wasn't sure how to say it simply, one way, so I said it in multiple ways lol. Sorry!
VladimirShuravi (05-17-2024)
luvofjah
04-14-2015 06:23 PM
AZ_James
07-06-2009 09:41 PM
