[TX] Springs, headers, Holley TBI T/A Seats and more
Old Dec 5, 2015 | 11:25 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
PICK UP ONLY at this time, unless noted otherwise! Katy (West Houston), Tx.
Third gen stuff.
$200 670 Holley throttle body modified w/ GM pod, 454 Injectors - willing to ship
https://www.thirdgen.org/forums/tbi/...ml#post4241739
$20 RIGID Trailer hitch
$5 ECM 1227169 (Came out of an '86)
$10 Gauge pod
$10 Serpentine bracket and w/p pulley
$40 Demon Carb manual choke kit 421441 - never installed - willing to ship
$30 Pair of 3/8" thick brackets for '2010 SS Brembo conversion - willing to ship
----- Holes were cut 19/32 instead of 9/16. Have 2 pairs available.
$10 GM 3.23 gears (used) 10bolt
$2 Strut tower caps
$5 Fan, tested and works
FREE 275/40R17 Tires - holds air
Non-third gen specific stuff.
FREE with purchase of anything else - Cadillac side airbag. Not liable for injuries caused when you decide to blow it up and post on YouTube.
Pictures Here
http://www.fototime.com/inv/53A170F44421E9C
Please MAKE AN OFFER if you see something you want. For these prices, I'm not really keen to ship the majority of it.
Best way to contact me is to email
*SOLD* $60 Ground Control rear adjusters NEW (Willing to ship)
*SOLD* $200 305 TBI engine 134k complete
*SOLD* $40 Serp accessory brackets
*SOLD* $500 genuine 1le spindles/brackets/calipers/jazz from '92 b4c/1le car
*SOLD* $30 Aluminum drums
*SOLD* FREE 10 bolt drum rear end 3.08 open
*SOLD* FREE 10 bolt drum rear end 3.23 open (no drums, some assembly required)
*SOLD* $250 Dynamic EFI EBL Flash
*SOLD* $20 305 TBI engine, was told it had a knock, no accessory brackets or pulleys
*SOLD* $20 305 shortblock (core) from a truck
*SOLD* FREE thirdgen starters
*SOLD* $425 305 TPI engine from '92 B4C 180k complete with ECM, accessories not original or tested
*SOLD* $225 GMPP Intake for vortec heads 12486572
*SOLD* $50 Suspension Techniques Springs Front/Rear set (fronts not pictured)
*SOLD* $200 (4) 16x8 '85-87 IROC wheels no centercaps
*SOLD* FREE stock panhard bar
*SOLD* FREE torque arm
*SOLD* Stock rear springs x3 sets
*SOLD* $20 (86) Gas Tank with crappy sending unit
*SOLD* $40 Hedman shorty headers plus y-pipe
*SOLD* $80 6874/7974 Edelbrock coated headers with AIR tubes, listed for 83- 85 L-69 H.O. 305
*SOLD* $40 Auburn diff
*SOLD* $10 Caster/Camber Plates, one side bent, both missing spacers, a bit rusty
*SOLD* $10 T5 crossmember
*SOLD* $150 Power Torque Clutch & pressure plate HP1675
*SOLD* $30 T5 'HURST' Shifter
*SOLD* FREE 14" steel rims
*SOLD* $5 2000 SS Sway bars, 32mm front and 19mm rear
*SOLD* $25 gray leather T/A 4th gen front seats. Drivers side heavily worn, big hole, no rails, not good condition
*SOLD* $20 Black carpet
*SOLD* $10 rear hatch motor (unknown condition) says '88 Camaro on it as if it was pruchased from a salvage yard
*SOLD* $80 Decent front gray seats from '92 RS
*SOLD* FREE Gray rear split seats
*SOLD* $20 Red interior from '92 B4C
*SOLD* $50 Hypercoil 9.5" 1000lb front springs & 200lb SSS rear springs (unpainted)
*SOLD* $50 Allstar p/n 56118 pair adjusters NEW
Old Dec 5, 2015 | 11:27 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Re: Engines, EBL Flahs, 1le brakes, springs
Lots more pictures Here
Old Dec 5, 2015 | 11:37 AM
3genpio's Avatar
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
Re: Engines, EBL Flash, 1le brakes, springs
Hi. Will take rear ground adjusters.
Hit me with your paypal. Need it to shipp to 60634 IL.
Old Dec 6, 2015 | 08:44 PM
xbazzarex's Avatar
Car: 1985 T/a, 1988 Formula
Engine: LB9 and LO3
Transmission: 700R4 and 700R4
Axle/Gears: 9 bolt 3.27, unknown
would also be interested in a few parts please pm if you willing to ship stuff.
Old Dec 18, 2015 | 11:03 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
What parts were you interested in?
Old Dec 18, 2015 | 04:23 PM
xbazzarex's Avatar
Engine: LB9 and LO3
pm'd and emailed.
Old Dec 19, 2015 | 05:12 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Interested in the aluminum drums if you're willing to ship to 99336.
Old Jan 2, 2016 | 09:24 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
First post updated to reflect parts sold, added some more stuff, and lowered some prices!
FWIW, I ended up shipping GC rear adjusters, engine mounts, and drums.
Old Feb 6, 2016 | 10:05 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Re: Engines, EBL Flash, springs
First post updated, added some stuff, lowered some prices.
Old Mar 17, 2016 | 08:32 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Re: Springs, headers, Holley TBI T/A Seats and more
First post updated again, added some stuff again, and lowered some prices. Don't be afraid to make me an offer.
Old Apr 1, 2016 | 02:42 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
April Fools pass on deals like these!
Old Apr 3, 2016 | 05:50 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Went to take pictures of the gas tank for someone, found MOAR stuff
Old Jul 19, 2016 | 10:53 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Re: Springs, ECM, Holley TBI Seats and more
Cleaned out my FIL attic, and came up with more parts.
Updated first post (and more pictures)
ALL pictures located http://www.fototime.com/inv/53A170F44421E9C
I can take more specific ones upon request.
Old Jul 19, 2016 | 11:14 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Everything in 1st thread with price is still available right?
Old Jul 21, 2016 | 11:56 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Yup, everything in 1st post unless marked Sold is available and still for sale. Updated pictures in others post to stay current with what's still available.
Old Jul 23, 2016 | 10:39 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Pulled the black carpet down from my attic tonight and snapped some pictures. Not bad, not great, just dusty.
customblackbird
LSX and LTX Parts
Apr 29, 2016 11:25 PM
Zylinder
Nov 16, 2015 12:11 AM
1988_f-bird
Nov 13, 2015 06:48 PM
Maredjathis
Nov 9, 2015 08:00 AM
oneleglance
DIY PROM
Nov 6, 2015 06:19 PM
