Speaker resistance
Old 09-19-2017, 01:49 PM
garys83's Avatar
Speaker resistance
I replaced the rear speakers(in the sail panels) in my 83 Z28 a couple of years ago. I am now getting almost no sound from the right-side speakers. I had a look at the rear speakers to find that they are Delco 4 ohm speakers. Is this correct? I thought factory Delco radios were paired with 8 ohm speakers?
Old 09-19-2017, 07:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Speaker resistance
I have a set of original 4 ohm 6x9 Delco's from a 87 TA.
Old 09-20-2017, 10:26 AM
OLDYELLR's Avatar
Car: '85 IROC
Try swapping them left to right. It could just be a bad speaker.
Old 09-21-2017, 08:08 PM
Saxondale's Avatar
Car: '84 Z
Engine: L69
If the radio is original could also be failing radio. Learned that from John in RI here on the forum. My radio started doing that, in '84 Z28. AM/FM ERS with digital clock.
Old 09-21-2017, 09:42 PM
OLDYELLR's Avatar
Car: '85 IROC
Yes, my original radio radio failed a couple of years ago. Loud motorboat sound from rear speakers. Parts no longer available to repair, but there's a guy on this board that has parts and can fix them. I found a replacement on eBay.
Old 10-24-2017, 10:03 AM
garys83's Avatar
Thank you for your responses. I had the radio checked and it is functioning properly. I have the original front speakers (8 ohms) and two rears from an original 3rd Camaro which are 4 ohms. Everything is working nicely now. I thought that all four speakers should have the same impedance. Thanks again.
Old 11-04-2017, 12:14 PM
CorvairGeek's Avatar
Engine: LG4
Transmission: 700R4/4L60
Learn something new everyday. I 'think' my A-bodies may still have 10 ohm speakers with the late ETR units. I did not realize GM started the mixed ohm speakers with the early ETR head units. I thought it was a more recent development, sans Bose and Monsoon.
I actually took pictures of the rear deck speakers (too hard to see, fused back that I would like to keep using for a while) in multiple of the last LeSabres (little double DIN project) because I couldn't believe the cars really came with 4 ohm in the front and 8 ohm in the rear.
They hold up well in my location (high desert), but I wouldn't advise looking for any cheap. The HU is impressive, but $50 pairs of speakers blow the OEMs away.
Old 11-04-2017, 01:11 PM
garys83's Avatar
Thanks for your reply. I have found a local shop that is going to repair/replace the foam around the cones and test the speakers. If this goes well...then I'll reinstall the original speakers. I am happy to keep it all original, I do not want/need a high sound system in this car. Thank you, Gary.
skyarme
Car Audio
04-06-2017 04:44 PM
Aerizanthar
Car Audio
03-30-2017 03:00 AM
Galaxie500XL
Car Audio
02-06-2017 06:30 PM
Timmie
Car Audio
11-11-2016 05:27 PM
scottmoyer
Car Audio
10-20-2016 07:45 AM
Quick Reply: Speaker resistance
