Weird 350 too no start.
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys i got a 91 gta with a 350 tpi....yesterday I barely started it to move it to work on it it barely started and sputtered......the fuel filter was clogged...i changed it and now it won't start at all....i have 44 psi when the pump primes..i took the pump out to make sure it was not clogged...i checked all the fuses they are good. I'm thinking a wire or something broke when I moved it. Any ideas would be great as I was barely got to get it registered to drive it.
Engine: 350 tpi
Re: Weird 350 too no start.
Yes i have spark...it was running yesterday when I moved it...the fuel filter was clogged. I had to get the fuel pump to prime 3 times before it would start. So I changed the filter..no i have new Injectors the motor was rebuilt. But now it won't even start just cranks.
Engine: 350 tpi
well that's the weird thing is it was running when I moved it it had no check engine light or nothing. I'm thinking a wire broke somewhere. It had spark and fuel like ibsaidbthe psi is at 44 when I prime the pump. I hear the injectors getting the fuel
Engine: 350 tpi
Well I found the problem. This wire got cut somehow and it was not making contact it goes into the pick up coil...of anyone has one laying around for sale please let me know. Thank you for all ur help.
Engine: 350 tpi
I found it on eBay thanks again.
coolrimsatleast
11-21-2006 10:12 AM
Reno
10-14-2001 08:16 PM
