Need help with these codes?
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
Guy says it has the handling pkg...Car is all original 137,00....It needs paint(white),never been painted...Car sat 2 years,charged battery and it fired with about 3 turns of engine...I drove car,runs,drives well,very tight....Has tilt wheel,crank up windows(which I like)it is hardtop...
He is asking 2000,00 for car.....But I still would like to know lil more about codes...He did say it had handling pkg....4 wheel disc.....He mentioned B4c,but I cannot verify without help...
Thanks for any help,JD
Here are the codes in hatch....
Re: Need help with these codes?
J65 is for the disc brakes. You can lookup pro codes online.
Here’s a few sites
http://rpocodes.com/GM-RPO-codes/gmr...GthroughM.html
http://www.chevy-camaro.com/chevy-ca....asp?year=1992
Here’s a few sites
Thanks for reply TP....I was mainly asking now if could be a B4C car?...he says it has handling pkg....
Thanks again,
JD
Thanks again,
JD
in my driveway now....Thanks for all help....
JD
JD
i'll get few pics tomorrow b4,and after clean-up
See how the SPID doesn't say B4C on it? That's how you know it's not a B4C. The fact it has Z28 is also a good indicator it can't be a B4C because B4C was an option on the RS only. That's also how you can tell it's not a 1LE. No 1LE code, no 1LE.
All you really need to know is the engine code. B2L or L98 (both actually) pretty much says it all. Pretty much all the performance options were standard with the 350 engine. The engine required the dual cats, it required the performance gear ratio, it required the FE2 suspension, it required the 245/50ZR16 tires.
1992 was one of a handful of years where ordering the 350 engine, actually automatically triggered all the good stuff. 88 & 89 were dark times when a 350 could be had with 2.77! gears!
Community Administrator
Please continue the discussion in the following thread in the History/Originality section:
https://www.thirdgen.org/forums/hist...z28-5-7-a.html
This section is for listing ThirdGens for sale - not discussing them.
Thanks for keeping things in order.
