HEADLIGHT HELP PLEASE
Engine: LG4
YES IVE LOOKED AT THE MILLION THREADS NOOOOOOOOOOOO NONE ARE ANY WHERE HELPFUL YES IVE CHANGED THE DAMN HEADLAMP SWITCH NO IT DIDNT HELP AND NOW I CANT FIND ANY MORE DECENT INFO ANYONE WANNA HELP
Re: HEADLIGHT HELP PLEASE
Whoa, whoa calm down a second. Were all here to help but you're not going to get much response sportin' a 'tude and bustin' caps. You didn't even say what the problem was.
Engine: LG4
my headlights went out so I replaced the headlamp switch which didn't help and just pissy cause I can't drive my car and I can't seem to find any solid notion
Engine: LG4
headlights were working then suddenly stopped last night. Interior lights aren't working but I also have the fuse pulled connected to the power antenna as the motor on that won't stop. Anyways back to the lights. so I replaced the headlamp switch and still no luck and just kinda running out of idea's
I swear I’ve seen the headlight switch wiring diagram around here just within the last half hour doing a search using “replace headlight switch” as the search. I would check the grounds and relays within the headlight wiring. I apologize for not being more exact but I’m learning these cars right now by rebuilding an 88 IROC as we speak. I understand the frustration though. Are your taillights working as that might rule some of the possibilities out?? Any other exterior lights working at all?
Ok there is not a lot of things to go wrong. Since both are out it’s most likely a common component or connection and they are headlight switch and dimmer switch. The headlights have separate grounds so that is unlikely. Fusing is provided by a fusible link you can test by checking voltage on the red wire on the headlight switch. No voltage there = blown fusible link. If voltage on red is battery voltage then check yellow with the switch in the on position. Again should be same as the red. If you get here dimmer is the next thing in line before the lights themselves and is suspect. You can access the dimmer switch and check for power through the contacts. If nothing is getting through then you found your problem.
This all assumes factory wiring.
Engine: LG4
I'm gonna try the fusible link tonight
that's my 300# fat *** contorting to get that stupid headlamp switch in while my buddy drinks lol
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
In Columbia, willing to help a fellow member if needed
hiller1162
07-04-2016 09:20 PM
Groove Merchant
07-27-2000 03:10 PM
