1984 ECM Lockup
1984 ECM Lockup
Hi!
Please help. Does anybody know why the the ECM provides 3 cables to lockup the Transmission?
We rebuild another Transmission and i have only 2 Inputs on the Transmission. One Ground that goes to a pressure Switch and than to the Solenoid and the
12V + coming from the brake Switch. So for what is the 3rd cable?
thanks alot
Martin
thanks alot
Martin
Car: check
Engine: check
Transmission: check
Re: 1984 ECM Lockup
The third wire is typically a pressure switch on the 4th (OD) circuit. Lets the ECM know when the trans is in 4th. Mostly uses that signal to use a different setup of TCC lockup tables. Versus the 2nd and 3rd gear tables.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Re: 1984 ECM Lockup
No need to connect the 3rd wire to anything. Sounds like the way it is wired is that it auto-locks once in 4th gear. This is common when lockup is desired on the highway and the ECM is no longer in place.
RBob.
RBob.
Re: 1984 ECM Lockup
Hi!
I have no Picture. The Transmission is on the car and filled with oil.
The rebuilder told me so: Pin A Goes the + to the tcc Solenoid. Pin B Goes Ground to the Two pin 4th Gear Switch and from this Switch to the Ground from the Solenoid.
So if the Trans is in 4Gear the Switch connects the ground coming from the ECM to the Solenoid.
What i do not know is what the 3rd cable is on the harness. If it is a 4th gear indicator for the ecm can i put ground to it?
Hope you know what i mean.
thanks
Martin
thanks
Martin
foney_email
09-15-2002 09:01 PM
formul8!!
11-10-2001 03:39 PM
Jer82Z28
09-01-2001 12:00 PM
MY87ROC
04-22-2001 04:06 PM
illegal87
03-29-2001 07:38 AM
