Oil pan clearance with UMI K-member
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Can somebody with a UMI K-member take a picture and measure the vertical clearance between oil pan and the K-member, and state which oil pan you're using? I've heard it is tight and nothing but an LS1 F-body style pan will fit, but hoping there's more room than the rumors say.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Oil pan clearance with UMI K-member
I don't have a picture handy but I too am very much struggling to get the proper pan clearance to the UMI k member. I need the engine to go forward about a half inch. I feel if I shim the trans mount and use three of the four bolts in their engine mounts I "should" get there. Running UMI road race k member with their mounts and an f-body pan.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
So basically what you're saying is the clearance is nearly nil.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Fact. As it sits now the pan is resting on the kmember. The engine needs to tilt in the mounts but you can't do that of you use all four mounting points. I'm also running OEM 4th gen engine side mounts with energy suspension bushings. Starting to get nervous.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Oh, boy, sounds like a broken oil pan waiting to happen.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yes. My project has stalled a bit until I can get this corrected. My backup plan is the holley pan which gives a lot more sump clearance to the k-member, I don't have a stroker, but would need to reinvest in all my windage mods.
With how much compression I had to put on the poly mounts during install on the 4th gen, might as well be solid at this point.
I haven't driven the 3rd gen yet, but during break in and other running time, didn't really notice them, no severe rattles or heavy vibrations.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I found some pictures that show the issue. At first I thought the interference is just the way the engine and trans was sagging in the mounts (unsupported at the tailhousing) but after bolting everything in I still have the issue. I might try to shim the resting height of the trans mount and see if I can "rock/tilt" the engine forward in the mounts.
You can see the lower k-member tubing sitting directly on top of the F-body oil pan.
Check out the first page of my thread. I have picture showing the front to back clearance. It's like post #5.
I have the UMI mounts slid all the way back to get everything to fit and have enough clearance. It looks like yours is all the way back too?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I will definitely check out your thread. My mounts are kinda all the way back. By that I mean that there are the four bolt holes that secure the mount to the K-member pad. Two of the bolts are all the way maxed on rearward adjustment. The other two could go back more. The problem is that I can't get all four back and still have the mounts attach to the clamshells. I might to try to remove the single mount bolt and adjust the k-member mounts. Then put the engine back in. I wonder if the poly mounts are creating a twisting effect preventing me from moving all four mounting locations as rearward as possible.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I just looked at your pics and your mounts look like they are slid all the way forward and you have clearance. All four bolts look like they have equal adjustment left. I am at the end of the slots with my brackets pushed as far rearward as I can. Hmm.
So I'm trying to remember how the install went when I was messing with the mounts.
Are the k-member pads side specific? I feel like mine were not, I could be wrong though.
Also, I had all the bolts loose when I was installing things.
Just to note I got my k-member a long time ago, 2014-15. So maybe they changed somethings?
I will say that I bet 50% of your problem is those poly mounts. Getting them in my 4th gen was a joke, I was using the scissor jack to force the engine over to the driver side. UGH.
The install with the UMI AL mounts was pretty darn easy.
Definitely try bringing the trans up to the right height.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I totally hijacked qwuiks thread. Hopefully this is helping him.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I ended up buying the UMI solid mounts. I'll post my results separately as to not be a total al Qaeda highjacker.
COTM Editor
I have used the UMI road race k member in several swaps and like it a lot.
If you look at post 10 in this thread of my son's LS3 swap into his 87 formula you will see what i do. i like the motor to sit a little more forward so i do modify the UMI motor mount brackets to give me more forward adjustment
https://www.thirdgen.org/forums/ltx-...-ls3-swap.html
This is with the holley LS swap oil pan and polley mounts
Also i had sent this info on better adjust ability to UMI last year and i think they were going to consider adjusting their motor mounts but i haven't verified it myself as my current project is using their k member with a SBC
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Indeed. I've referenced your thread many times, including earlier today, and I love that way you built that car. I have a few questions that I might reply to your thread with.
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
i have the UMI roadrace k-member and an LS3 w/ pan # 12628771. There is boat loads of clearance between the pan and the K-member.
Please excuse the filthy car that i haven't touched in 3 years.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
That looks perfect. What engine side bushings are those? OEM 4th gen with stock bushing?
My UMI solid mounts haven't come in yet so no update.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Why does everybody end up with something different?
Motor mounts adapters are the UMI LS adapters.
Motor is adjusted as far forward as it will go, which was dictated by the hawks t56 trans-x-member.
FWIW, UMI originally sent me the wrong adapters and it took an insane amount of prying to get the k member installed to the motor out of the car. I mean insane. And when i looked at the motor mounts they were being torqued very hard. I sent them pics and told them about my problem, a few days later i had the correct plates and everything went together smooth as butter.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
OEM,
I too already went through this. I am certain I have the right brackets. I am pretty sure it has to do with the energy suspension bushings.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The new UMI brackets are in and engine placement is better but not ideal. I spent hours trying to balance fitment with bracket placement and I ended up with about 3/8" clearance between the pan and k-member. I think I'll risk it and move forward. I am out of options. I do think the mounting height of the magnum T56 is different than T56 with the body tail housing. This is the one variable that seems to affect my pan clearance the most. I need to create about a 1" spacer block between the trans mount and trans cross member. If I dont space it, the drivetrain rocks and then the pan is back to hitting the kmember.
New mounts are nice
There is clearance, but not much
Mounts pushed back as far as possible
With the trans pushed up (better shifter placement too) you can see the gap I need to fill between the mount and the BMR cross member.
New mounts are nice
New mounts are nice
New mounts are nice
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Indeed, which is why I can live with the small clearance. My only other option is to switch oil pan setups to the Holley but I'd have to buy new baffles and crank scrapers and that's quickly another $1000. My teeth might suffer with these mounts but not as much as my soul if I dont get this girl on the road.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'm enjoying the pictures and extra info in this thread. Just the kind of stuff I wanted to know.
I'm guessing you're focusing on fore-aft clearance between sump and crossember. How much space is between the front of pan and top of crossmember?
The engine pivots at the mounts, not on engine centerline, so any movement will tend to lift the pan away from crossmember. I would guess worst case scenario is just like it sits now at rest.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
if you need a picture from a different angle let me know.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
My sump will easily clear fore-aft. It's the gap on top side of crossmember that I'm concerned about because the front of my pan is deeper to clear stroker cranks.
I have the Holley 302-1 pan. I'm getting the idea that it will clear just fine. Pan dimensions, along with other LS pans, is shown in Post #935,
https://www.thirdgen.org/forums/ltx-...ml#post6193942
I can confirm that the trans mount surface on aT56 Magnum is machined 5/16" closer to the trans output shaft centerline than the 4th-gen F-Body T56 trans mount surface is.
Be aware that the mounts themselves cause confusion for many users as they are not consistent heights. The Prothane poly trans mount is 1-3/4” tall and the common Energy Suspension trans mount that everyone uses is 3/16” taller than that when you use the required pre-load plate it’s shipped with.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Glad to help you out with the info. The Hooker Blackheart 3rd-gen transmission crossmember is compatible with a T56 Magnum transmission as long as the engine/transmission mating plane is located in the same fore/aft location as provided by the Hooker Blackheart 3rd-gen LS engine swap mounting brackets for the stock K-member. The positioning used for that system is the same configuration GM used when they switched to the LS engine in 4th-gen F-body cars (the engine/trans mating plane was moved forward 5/8" form the previous SB Chevy position). If the engine/trans mating plane is shifted rearward, then interference of components quickly follows as you've discovered. It also affects the installation of 4L60--4L70 and 4L80 (especially this one)transmissions in a negative manner.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You can see member skinnyz using that combination of components together in post #551 of the the "Third Gen Dual Exhaust Picture Collection" thread.
COTM Editor
Also just for reference, in the referenced thread below you can see what trans mount, etc that i used with the blackheart crossmember... the t-56 magnum that we used, we had a 4th gen tail on so of course is different than yours, but overall we did get the magnum to fit with this combination of parts... i do really like the holley cross member... easy to adapt for better torque arm than the stocker
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
COTM Editor
when I started looking for the tranny for my son's swap, bruce told me that they had just started carrying brand new magnums with f body tailhousings so I decided to go with that... hawks sent it as a complete transmission ready to go... other than getting the drive shaft yoke squared away (it uses a special yoke with the internal spline machined for the right insertion clearance for the tail housing it was a snap to put in
https://www.hawksmotorsports.com/82-...-engines-only/
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup, then I still stand by my original assessment of non compatability. It's not that big of a deal.
LT1Formula
11-16-2015 01:13 PM
