Fuel pump wont shut off
Old Nov 18, 2025 | 09:19 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Transmission: 700R…for now
Axle/Gears: 4.10
I converted my car to 4 barrell last year and now I have a problem with the fuel pump running at all times unless I unlug the oil pressure sensor, pull battery cables or pull the fuse for the fuel relay…..anything helps!!
Old Nov 18, 2025 | 10:19 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Fuel pump wont shut off
It sounds like you have a failed oil pressure switch. The contacts on that switch are normally open, and only close above 5psi of pressure. Replace that and re evaluate
Old Nov 18, 2025 | 02:46 PM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
That part is brand new.
Old Nov 18, 2025 | 03:00 PM
RottenThomas's Avatar
Car: 1989 Camaro Iroc-Z Z28
Axle/Gears: 2.77 G80
What about the relay? Can even try tapping on it. Could be stuck closed... Maybe even an exposed wire somewhere. A repair manual would have the diagram and check procedures.
Good luck to you brother ✊
Old Nov 18, 2025 | 03:06 PM
If unplugging it cuts the power to the fuel pump, it's messed up.
If it's messed up, doesn't matter too much how new it is.
​​​​​​​Replace it.
Old Nov 18, 2025 | 03:12 PM
Let us know what you find out.
Old Nov 18, 2025 | 04:06 PM
Indeed. Might even be the wrong one, somehow. Can't imagine how butt you know how that goes.
Old Dec 1, 2025 | 06:49 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
I replaced it with a new one and same thing. Got some new relays, same result..... now on to chasing wires and maybe even changing the pig tail for the oil sensor.
Old Dec 1, 2025 | 08:24 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You can trace down what's wrong with a multimeter and knowledge of a wiring schematic.
Old Dec 4, 2025 | 07:38 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
Yes that is my goal for this weekend, Austinthirdgen.com has all the schematics.
Old Jun 3, 2026 | 06:41 AM
Cwolfe092's Avatar
Car: 92 RS- hardtop
Axle/Gears: 4.10
Im back after six months (3 months were straight 7/12 work schedule) and after swapping fuses, chasing wires, measuring everything with meter, pig tail, and I had finally just ordered one last damn sensor. This time I went with the GM manufacturer one that was $60........ swapped it out and instantly problem solved.....I guess this thing doesnt like the cheap sensors.
generalchase
Apr 24, 2016 09:14 AM
krazymatty
Sep 4, 2009 08:36 AM
CamaroFreak87
Jul 11, 2005 10:36 AM
crnsuperduty
Mar 23, 2005 10:16 PM
dwillms
Jun 22, 2004 12:05 AM
