Hard Starting Issue Making Me Pull What is Left of My Hair Out
Old Apr 15, 2026 | 02:20 PM
Smykster's Avatar
Car: 1991 RS 305TBI
Starting Issue on 305 TBI driving me insane and is getting progressivly worse. This used to happen every once in a while when I got it 2 years ago, now it happens every time I got to start it:
When I turn the key, the car will crank and fire only to die half a second later. It will do this about 4 times before it finally starts and goes into idle. I can also rev the engine right after it fires to keep it going and get into idle. Seems to run normal after that until lately. If I turn the AC on when warmed up, it will stall sometimes unless I rev it a bit before turning on the compressor.
I have thrown the parts cannon at it:
2 New IACs
New TPS
New EGR
Rebuilt TBI
New Fuel Pressure Spring
New acdelco injectors
New ICM
Spark plug are a year old as are the cap and rotor
New Fuel Filter
New CTS
New Fuel pump relay
No engine codes and WINALDL is reading that it is running slightly rich, blms are usually under 128. Vaccum test shows 21 in-Hg. The kpa readings form map seem normal, the temp reading from the CTS seem correct. TPS .57v. Only thing I have not checked is timing.
The pump primes when I turn the key and I also tested the fuel pressure, priming goes to 9psi and running at 10 psi. If I give it a rev, it is steady on 10psi. Seems to be low but still in spec or GM's 9-13psi. Does this feel like an ignition issue or fuel issue? Any ideas what to test next?
Old Apr 15, 2026 | 06:56 PM
Vader's Avatar
Re: Hard Starting Issue Making Me Pull What is Left of My Hair Out
Agreed that the fuel pressure is a bit lower than a comfort-level measurement. I fought a couple of TBIs with pressure on the low end and they were temperamental, fussy, and quirky in some of the operating modes. One was a Fiero manual, and when I modded the TBI pod to regulate pressure up nearer the 13 PSI end, several troublesome issues improved.
Old Apr 15, 2026 | 08:57 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I agree. The fuel spec is dumb, they 'like" the very top end of the spec and suffer when they're below that. That spec represents a whopping 44% range in "acceptable" fuel pressure!? Give us a break. That would be like expecting a TPI engine run run 'fine" at 24 PSI. Would it? No.
Get the fuel pressure up to 13 or 14 pounds, then see how it runs.
Old Apr 16, 2026 | 06:38 AM
Smykster's Avatar
Car: 1991 RS 305TBI
Thanks guys, looks like it's fuel pump time... Now I have to muster up the courage to drop the rear.
Old Apr 16, 2026 | 08:34 AM
Engine: LT1, L400
Dropping the rear is not hard.
Buy a fuel pump for a MPFI application...not a TBI replacement pump.
Old Apr 16, 2026 | 09:56 AM
Vader's Avatar
It may not need a fuel pump. The FPR in the "rebuilt" TBI unit may or may not be set where you need it. The replaced spring may also not be sufficient.
If you restrict the return line and test the dead-head pressure of the pump, you can find out. It will require a few adapters and fittings, but is all top-side work and probably easier than dropping the fuel tank.
Old Apr 16, 2026 | 10:17 AM
Engine: LT1, L400
Vader is right. Do what he said, first.
Old Apr 16, 2026 | 10:27 AM
Smykster's Avatar
Car: 1991 RS 305TBI
What kind of pressure am I looking for on a dead head test? 15psi+?
Thanks again guys.
Old Apr 16, 2026 | 11:15 AM
Engine: LT1, L400
15 PSI would confirm that the pump CAN go higher than the 9-10 pounds you're seeing now....and that adjusting the regulator is all that is needed. Currently.
The TBI pumps are typically pretty crappy...I'll be surprised if you see any more than the 9-10 pounds you're already seeing now, since the pressure SHOULD always be, whatever the reg is set at, on those. Since you see a peak of 10 lbs, it should be 10 lbs all time; idle, WOT, 500 RPM, 5000 RPM....10 lbs. -Or whatever it's actually set to. So to me, since you mentioned 9 lbs but gets up to 10 lbs....I think the pump is suspect, but a test is in order, for sure.
Old Apr 16, 2026 | 08:10 PM
Vader's Avatar
The prior assumption could very well be correct, but an extra bit of time checking it out from the top could save a lot of frustration if changing the pump does nothing for improving pressure.
Yes, a pump without a return line could hit 20 PSI, but don't run it that way for more than a few seconds. I don't believe the later years had the pulsation damper in the tank like the '84-ish models had, so there should be no risk of bursting that.
Also, I've had a couple surprises "fixing" fuel pumps that wouldn't consistently make pressure. The one in the photo came out of the tank exactly as you see it, and sometimes would make the correct pressure. The car had been in an accident and I think the kinetics of the impact did the "inertial disconnection" shown.
Anthony0128
Dec 8, 2016 11:54 AM
xplane
Aug 24, 2009 03:55 PM
tpi90rs
May 20, 2009 11:03 AM
nikkev
Nov 5, 2006 07:28 PM
