Finished engine pics.
Old Jun 14, 2003 | 10:21 PM
JR305's Avatar
While I was waiting for a friend to come over and weld up my exhaust and LCA relocation brackets so I can drive the car I took some pics of the engine. Can't wait to have it on the road, it's been a 5 month project. So how does it look?
Old Jun 14, 2003 | 10:25 PM
Pew's Avatar
Pew
Car: 90 camaro
Transmission: t10
Axle/Gears: 9" with 4.88's
looks good man congrats on a job well done.
Old Jun 14, 2003 | 10:40 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
all i have to say is DAMN, looks wicked
Old Jun 14, 2003 | 10:43 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Looking Good!
Old Jun 15, 2003 | 10:31 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
WoW LOOKS Awesome! Nice job
Old Jun 15, 2003 | 10:56 AM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
just one small thing
all id say u have left to do is get a new GM over flow tank and washer fluid tank and it will look 100 x better up front other then that it looks pretty dam good.
Old Jun 15, 2003 | 11:28 AM
MdFormula350's Avatar
wow looks awesome, that thing is going to be fast :hail:
Old Jun 15, 2003 | 08:28 PM
JR305's Avatar
I know, I tried to clean them but that was the best I could get. Does any one know a good place to get them and how much they cost?
Old Jun 15, 2003 | 08:37 PM
nolanr0413's Avatar
Car: Trans am
you can get them from gm still, i have an 85 trans am and i bought the coolant overflow tank for 12 bucks, and it was brand new.
Old Jun 15, 2003 | 09:07 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I love the look of that intake. I bought the coolant tank for my 90 off ebay for 18.00 .
Old Jun 16, 2003 | 05:34 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Nice looking motor! I have a similar setup. I'm curious to see how much power you put to the wheels. The 276 is an awesome cam!
Here's mine:
Old Jun 16, 2003 | 08:24 PM
OMINOUS_87's Avatar
JR
I got new plastic tanks. Brown & Brown, should be less then 30$ for everything, new coolant tank, new washer fluid tank, and caps.
I only bought the coolant tank and cap, I am not going to run wipers as the wiper motor looks real sh_tty next to the Superram, I also mounted my ignition where the washer fluid tank sat. The tank is smaller though, pic shows.
Otherwise it looks great
BTW: The 383 is in, just got to finish up the acessories.
Old Jun 16, 2003 | 08:28 PM
OMINOUS_87's Avatar
pic
Old Jun 16, 2003 | 08:50 PM
JR305's Avatar
So am I. It will be interesting to see if the Pro Toplines are as good as they seem. So when are you going to get yours on a dyno?
Sweet. When do you expect to be on the road? I just have to get a friend to come over and weld up my exhaust and suspension parts, and then I am on the road. Hopefully I won't have to deal with emissions until November. That coolant tank looks great, I am definitely going to swing by and pick one up. I was expecting them to be pretty expensive, since prices for most parts from GM dealerships are outrageous.
Old Jun 16, 2003 | 09:59 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Re: just one small thing
Dtich em both, aluminum catch can, and just get rid of the wiper fluid bottle.
Old Jun 17, 2003 | 07:25 PM
mastrdrver's Avatar
Man, your killing me. I cant wait to see what kind of #s you run.
Old Jun 23, 2003 | 10:48 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
JR305 - How's the car coming? Have you driven it yet?
Mike
Old Jun 23, 2003 | 12:23 PM
JR305's Avatar
Yep, I have the car on the road. Don't have the speedo hooked up yet. I was working on that Sunday night but ran out of the wiring I was using, so that will have to wait for this weekend. I posted an update in the TPI forum under the post "My new engine, Pics" but I guess no one is reading that post due to the length.
Engine is running great. The cam has more low end power than I though it would, completely drivable, no low vacuum problems (brakes/power steering).
I do have some bugs to work out though. I think me not having the speedo hooked up is causing one of my problems. Some times when I am driving and engine brake to slow down I get an SES light. Then if I let the car come to an idle it will die. I also have an oil leak that needs to be tracked down. I think I have a dead cat converter too. When I was putting my exhaust back on I could hear some rattling in it when I shook it. Sounded like something was kind of just rolling around in there. Would a dead cat quiet the car down, I think my old engine was louder. So I will probably end up replacing it.
Old Jun 23, 2003 | 12:31 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I still have to rewire my SGI-5 to get my VSS working (it's a pain in the as$ !!)
You could just do what I did and burn a chip with the VSS diagnostics turned off and this will correct the SES light and the car dieing at idle.
Do you have custom programming? If so, do you do your own like me, or do you outsource that?
I told you guys (in Mike Crew's post) that the XR276HR-12 is badass!! It's a nasty little cam that is VERY streetable!
Mike
Old Jun 23, 2003 | 02:29 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
sweet looking...
you need a cai setup or something tho
Cleotiz
Jan 6, 2018 08:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
