Unable to save sig
Unable to save sig
Hey guys i am unable to save my sig for some reason.
I have tried just a pic '150x100' and i have tried just
a plain web link but neither worked. Here is what i was trying to do...
http://www.planetjupiter.com/transam/
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Re: Unable to save sig
Similar issue, I cant update my Avatar.
Dunno if it's because I havn't been on much?
Community Administrator
After uploading, click on this link:
Which then inserts the sig code in your signature:
I went ahead and did the above, for you.
Signatures will automatically display for those who create a new thread (why your signature appeared in the first post of this thread), but all who reply to an existing thread will need to manually check the "Show Signature" option below the message box where you type your response. This is to help minimize those who frequently post their signature each and every time, which many users find to waste screen space. It has been setup this way for several (4+) years.
Hi JT, was my error. Been awhile since I've been on and used things. Thank You.
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
I think I'm having this same signature problem..
does it show up instantly or does someone have to verify and process the picture?
Signatures are not moderated in the sense that they do not require pre-approval. Your signature appears legit as it's in your profile.
You may not be aware of this, but if you respond to an existing thread, you must manually check the "Show your signature" option below the message area that you type in your response. If you are creating a new thread, the "show your signature" will automatically be selected. Why? It was setup this way, several years ago, to help (in a small way) to reduce redundant signatures.
i want to change my avatar also, but i can seem to find where i can. i wanted to change to my engine pic that i just uploaded, but i can only put the pic as my album default.
