South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Posi-Trac?
Old Apr 8, 2005 | 11:07 AM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Posi-Trac?
Quick Question, How do I know if I have rear posi-traction? Did any iroc's come with it? Posi-trac is when both wheels spin at the same tiem right? Like I said before I don't know much about the mechanics of cars, only what I have learned on these sites. One more question. What is the advantage of posi-trac?
Old Apr 8, 2005 | 11:46 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
The easiest way to tell is to jack up your car from the rear end and spin the rear tires with your hand. If the other wheel spins in the opposite direction, then you have an open rear end. If they spin in the same direction, then you have posi.
The benefits to posi is of course that both wheels put power to the ground, instead of one. Posi rears are a little worse than an open rear in the rain, but who cares about that.
You can find the gear ratio of your rear end by looking up your car in the tech articles on the page.
Old Apr 9, 2005 | 03:09 AM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
i believe all IROC's came with posi/limited slip....and some Z-28's it depends on what year...but im pretty sure your's gots posi.....try and find out what gears you have..either 2.73, 3.23, 3.42 ....i still need to find out mine (2.73) ?
Old Apr 9, 2005 | 06:54 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i want to trade someone my lsd 3:23's for their lsd 2:73's if anyone is interested. lsd= limited slip differential
Old Apr 9, 2005 | 10:08 PM
rudyt5000's Avatar
im interested...but why ?
Old Apr 10, 2005 | 10:06 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: Posi-Trac?
Do a search on the transmission and driveline tech board! Tha t question has been asked about a million times on that board! Everything U need to know is there including the answers to your questions and a lot more!!!
Old Apr 10, 2005 | 04:16 PM
because i have a th-350 with a 3500 stall and want to get a little better highway speed out of her, plus i dont plan on keeping the 2:73's that long before i get my 9 inch so i just want to try them out for a while, let me know, i can swap them in about 2 1/2 - 3 hours , you buy the fluid
Old Apr 10, 2005 | 08:22 PM
USA_Rally's Avatar
Car: 92 Rally
I just upgraded my car to posi track and have 2.73's in my stock rear end that is just sitting in the garage. let me know.
StealthESW
May 11, 2014 01:51 AM
jsanders
Jun 5, 2011 10:56 AM
compuwiz1937
Jun 14, 2006 08:20 PM
91_5.7_TPI
Aug 30, 2005 04:01 AM
BryanJ
Jan 24, 2001 01:32 AM
