Grinding noise please help
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
I have to type quick and cut straight to the chase since I am on work and I am not suppose to use the computer. I lifted the car up and hit the gas while the car was in the air, when I get up to 50mph the car starts to make a strange grinding noise. We had just finished changing the brakes. Can someone please help me figure this out. I will be able to use this thing again before I leave tonight.
Sorry to hear about your car RUDY!
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
probably too late to do you any good now, but the rear end will make all kinds of strange noise freewheeling at speed up on the rack, a peg leg rear is louder than a posi.
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
If it does not make the noise when it is NOT up in the air--don't worry about it.
Does it?
I thought U did brakes a couple months ago?
It could be the halifax not lined up with the larsis! Or possibly the kanuter valve is clogged up!
Does it?
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Does it?
Does it?
yep those kanuter valves can be a bitch, i remember when my halifax got lodged in my extruder and cause a hell of a mess
Car: 1989 IROC Z-28
DENN_SHAH
U should be ashamed of yourself. U shouldn't tease Mike like that! He's a good guy and this is his first car. U know good and well, there is no such thing as muffler bearings on a thirdgen! They use bushings!!!
http://www.drclassic.com/catalog/Cam...st/Z00092.html
click on the link above --see, they are bushings, not bearings!
opps,.. sorry
, but i always thought those were the manifold bushings,.... different from a muffler bearing,..
i know these are the old style, & they don't seem to last very long,
http://www.mufflerbearings.com/
or the new style,
http://www.kalecoauto.com/general.htm
they also have some other good stuff there, like crossdrilled brake lines, camshaft rotational dampeners, & something i need for my car, chromed hollow spark plug wires.
be sure to check out the Products section here, they have lots of great hard to find stuff.
http://www.mufflerbearings.com/products.htm
, but i always thought those were the manifold bushings,.... different from a muffler bearing,..i know these are the old style, & they don't seem to last very long,
or the new style,
nah
It does not make that noise when it is on the ground.
Thanks for all the hel[ guys. I did the front brakes a couple of months ago. We just did the back brakes.
sjorgens
Oct 1, 2015 07:54 PM
