South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Engine swap regulations in Texas smog counties
Old Dec 27, 2007 | 12:06 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
The bonus and tax return are looking like prime candidates to fund an lsx swap...
Anybody have any luck getting a 5.3, 5.7, or 6.0 LSX to pass emissions down here in Houston? I'd be running a cat and any original smog equipment.
Old Dec 27, 2007 | 08:22 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Engine swap regulations in Texas smog counties
It will be OBD II after that if it is still injected. As long as all sensors are good the computer will send ok codes and it will pass and not have to touch the dyno. But a big cam and what not will send it down hill.
Old Dec 28, 2007 | 10:49 AM
Stephen's Avatar
Car: 87 GTA
Our Austin LS1/3rd gen guys had no problems passing the smog tests.
Old Dec 28, 2007 | 03:24 PM
Car: 1987 GTA
Transmission: 4L60e
That's good to hear. Do you know if any of them are running the 6.0s?
Old Dec 28, 2007 | 03:35 PM
Stephen's Avatar
Car: 87 GTA
Both are the 5.7 (5.6, 346 cui in reality, I think it is) LS1s from F-bodies.
Old Dec 29, 2007 | 04:57 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
in Texas when a car goes in for inspection, its typed in by model year of the car, not the year of the motor. so for an 87 it still goes on the dyno. the sticking point is the emissions components.
my car never came with TPI fuel injection. i asked about it when i got my state inspection license & they couldn't really give me a good answer at the time. the only emissions part my car doesn't have that the stock motor had is a hot air tube, but because there is no place for 1 they said it doesn't need it. as long as its clean at the pipe & everything looks right under the hood & you have cats you should be ok, at least thats what they said about my car.
Old Dec 29, 2007 | 05:14 PM
Stephen's Avatar
Car: 87 GTA
PER THE BOOKS (my wife was the supervisor at DPS for department than covered all the inspection stations, which means smog testing) you can put newer engines in older chassis, but not older engines in newer chassis. Like, an older 327 in a 3rd gen.
Or if that chassis never came with that engine, like a big block in a 3rd or 4th gen. By the law, you can't do it.
Not that any of the inspectors care enough to look that hard.
And all OEM equipment must remain on the chassis/engine. If it came with a cat, it still has to have one. If the engine came with AIR tubes, they must be on there now.
Besides, it's still my argument, that if the REAL purpose behind smog testing is to reduce emissions, then JUST put the probe in the tail pipe & test! If the #s are good, then you pass. If not? You fail. I mean, if my engine runs clean without the AIR tubes & cat, who cares HOW I got the #s, as long as I got them.
Old Jan 20, 2008 | 11:08 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Several responses come to mind.
1.) Stephen is exactly correct -- in TX, the purpose is more revenue
enhancement than emissions reduction.
2.) The rules are clearly the rules. And its also clear, that many of
the ya-hoos inspecting vehicles are (a) illiterate, and can't read
the rules, (b) younger than these vehicles, which means that
considering (a) they're not highly motivated/skilled to do research
re: rule specifics.
3.) Search this forum for a shop on Fairmont Parkway, that is highly
recommended, i.e., knows how to work with our vehicles.
4.) There are board members who know where inspections can be
purchased, regardless of vehicle condition -- and priced accordingly.
Good luck,
kk
Old Jan 23, 2008 | 10:57 PM
Car: 1987 GTA
Transmission: 4L60e
Thanks for the advice. I'm in the buying phase of an engine rebuild on the L98 - and hopefully some brakes from ebMiller. With 170k on the clock, maybe it was time for a rebuild anyway. Anybody have an AIR system off an 88+ TPI they're willing to part with? Surely someone has one already off the car and lying on a shelf...
Old Jun 26, 2010 | 08:03 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Stephen is dead on. I would add that when I trained to inspect cars, We were also told that if I came in with the 85 Z28 I am about to buy, but I put in it a mid 90's LT1 in it by law as I was taught they have to test at whatever year that engine came out of, if it came out of a 93 then it has to pass 93 smog standards, not that all inspector look or know to look, but you could get a hard nose and have a hassel. And it is a bad idea to buy a sticker on the sly, If you get busted it will cost more in fines then to do it the right way and in some cases you can lose your car.
Old Jun 26, 2010 | 08:20 PM
Stephen's Avatar
Car: 87 GTA
None that I know of. Only 6.0 I know of is a friend of mines 6000lb 2001 Tahoe, on 24"s with a VERY full audio/video system, that is Whipple supercharged putting out 650p & running 12.85@105 quarter times!
1/4 mile pass
Just playin around
Old Jun 26, 2010 | 08:47 PM
Car: 1987 GTA
Transmission: 4L60e
Wow this thread is back from the dead. I'm neck deep in trying to get an LS1 swap done and have already passed inspection
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
