South East Region Regional Board for South East Members.
Car inspection questions
Old 02-19-2009, 10:40 PM
5thFbody's Avatar
Car: 87 LT bird,82 Trans-am
Engine: 305,383
Transmission: auto
Axle/Gears: 10 bolt 2.73,323
ANybody living in NC tell me what might make my car not pass inspection down here.I transplanted this one from up north.It has a crate 383 with no smog equipment,and exhaust dumps right in front of the axle. All the lights and signals work along with the horn.
ANy tips?
Old 03-01-2009, 01:29 AM
86WS6's Avatar
Location: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: Car inspection questions
You will encounter a problem. All counties in NC do inspections. Some counties do emissions inspections, but only back to 1995. All counties do a visual inspection to see if the OEM smog equipment is in place. The key is that it has to look like it is working. That's were they will get you. On a pre 95 model and older you can gut the cat, put it back on the car, and pass because it looks factory, but you can't run without a cat. If your car is supposed to have a cat, air injection reactor pump, EGR, PCV, and other items, and it does not have them, than it fails. You may be able to find an independent garage that will do an inspection and not look under the hood. Ask around where you live and work, and maybe someone can recommend a garage that does not check too closely.
Old 03-01-2009, 07:41 AM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
I didn't have a cat on my car at all when I went to get it inspected b/c the previous owner had removed it. So, the shop stuck me for $400 for a new one. Even if you just buy a shell, have one on there or they'll get you.
MustangBeater20
10-29-2022 09:20 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
slade5612
08-11-2015 07:19 PM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: Car inspection questions
