South West Region South West regional discussion board.
Help Me Pleaseeee
Old Oct 29, 2002 | 07:37 PM
89ReDIrOcZ's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: 700r4, Shift Kit
Help Me Pleaseeee
Hey guys, my car today just died on me i got home from school and when i went to turn it on again about 20 minutes later it dident want to start. well when i turned or tried to turn in on it dident do nothing no noise no click nothing. sterio and lights seemed to work good and they dident dim when i tried to turn it on. well my friend told me it was tha starter. can anyone help me out on this if it is tha starter can someone come fix it for me ill buy the beer or give u a lil something for ur troubles. thanks
Old Oct 29, 2002 | 08:32 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
For some reason I dont think its your starter. is your batter just dead, sometimes it will have enough juice to run your lights and all but not start your car. go to autozne and have them charge it. also get your alternator tested while there. if it turns out to be your starter i have the one off my 89 formula 350 that would work. i just finished putting another starter in my car about half hour ago. let me know. where do you live?
Old Oct 30, 2002 | 02:36 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
If it was your starter it would usually make a clicking sound when you try to start it. I would also try the battery first. After that check the nuetral safety switch. Then I would check the power to the starter. Then the starter.
Old Oct 30, 2002 | 12:04 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Any updates? I agree with azvolfan, there are a couple different things that I would check, including your VATS unit.
Old Oct 30, 2002 | 12:22 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
Didnt think about the vats. might have just blown that fuse. its located under yur dash. you have to unscrew thecomputer port or whatever you call it but thatswhere the vats fuse is located.
Old Oct 30, 2002 | 01:33 PM
89ReDIrOcZ's Avatar
well it turned on today. but when it was idleing if i tried to step on tha pedal it would like try to die off. Tha has been happening for a while already but i havemt had tha money to have it checked. dont got a job and im in need of one badly. im going to check tha vats right now if i can find them. anymore ideas what it can be.
Old Oct 30, 2002 | 01:35 PM
89ReDIrOcZ's Avatar
nuetral switch ? dont know where thats at, power to tha starter? i need help im not really that great on cars. im just learning as i go im still 18 tring to figure out all these things.
Old Oct 30, 2002 | 02:21 PM
cg91ta's Avatar
Do you have a multimeter?
Take your battery out and take it down to AutoZone or Checkers and have them test it. If it's fine then you have a lot more work to do, if it's not, replace it and you should be good to go.
I'll pm you with a couple other things.
Old Oct 30, 2002 | 02:57 PM
89ReDIrOcZ's Avatar
cg91ta i sent u a message and no i dont got none of those things and its a long walk to carry that batery to autozone i got no way of transportation.
Old Oct 30, 2002 | 06:28 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
you have no friends?
Old Oct 30, 2002 | 06:34 PM
89ReDIrOcZ's Avatar
yeah i got friends but they dont got cars. i really need to talk to more people with cars hehe i just got here so im still seeing if i find more friends out here.
Old Oct 30, 2002 | 06:57 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
oh ok
you got a few bucks? you can always get a taxi or ride the bus
Old Oct 31, 2002 | 02:49 PM
86LB9's Avatar
Where are you located? If your close, I might be able to give you a hand.
Old Oct 31, 2002 | 04:04 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Man, phoenix people are so nice to each other!
Old Oct 31, 2002 | 04:36 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
im from tucson
Old Oct 31, 2002 | 04:45 PM
89ReDIrOcZ's Avatar
YUP people from phoenix are nice. thanks Chris for coming down. 86LB9 thanks for offering help, but chris helped me out today thanks anyways bro ill call u next time hehe
irocz253
Carburetors
19
Aug 3, 2014 07:01 PM
Sam L.
Mar 25, 2014 12:24 PM
irocz253
Carburetors
Nov 26, 2013 09:46 AM
leezickmund
Carburetors
Apr 28, 2013 07:57 PM
thegoochking
Sep 13, 2010 04:55 PM
