driveshaft question
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
driveshaft question
will a 2.8 driveshaft work on a 91z28 or are they made weaker or sumthin? and the 2.8 has 323's and the z28 has 273's, are the v6 gears made weaker also or what? thanx
i am not completely sure, but i think i remember that all f-body driveshafts (82-01) are universal. You could probably find an aluminum ds off ebay for about $130.
As for the gears.......
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
No, it will not. At least from what I understand. From the info that I have, the v6 fbodies had 2 peice driveshafts and it will not work on the v8 cars. Now if it's a 1 peice unit, then it might but I don't know for sure.
Guest
Posts: n/a
measure the driveshaft from end to end and do the same for the other if it's the same tranny length (700 R4 and T-5) and they're the same length then they'll interchange
no the V6 gears and rears aren't weaker... all 10 bolts are weak to begin with
Transmission: t-5
the z28 has 273's and the v6 has 343's,i am thinkin bout swaping the gears into the 91 so itll have limited slip w/ 343's... the v6 driveshafts one piece,both cars are manual
Transmission: t-5
damn,i was really hoping i could switch em out...the 273's kill the car lol.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
3.08 and numerically lower ring gears are thicker then 3.23 and up. You may be able to get a spacer and use the 3.42.
Transmission: t-5
well ,someone sell me some 342 or 373 gears. or even a whole rear w/ posi.anything but these damn 273's lol
Transmission: t-5
well i dont need to worry about the dirveshaft,i changed the u joints n it runs smooth now.no more vibration,now i just need some gears so i wont be so slow lol
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
dude.. you can take the entire rear end off from the v6 put it on the z28 and the z28 to the v6.. no problems perfect match.. no questions asked...
on the other hand i doubt the driveshaft will work
hey sebastian.. you know what works wonders?
the search button
Shawn
the search button
Shawn
Originally posted by 82Z28NAZ
they have the spacers at Loper's. I saw them today.
Transmission: t-5
shawn,gotta go talking smack again dont ya....all i gotta say about that is check your fuses.haha. well im sure the shaft would have worked,their the same length and everything.but i wasnt sure about the strength. and i know the rear end can be changed. just the strength issue.... i dunno,i think ill just rebuild the rear in school sometime and change to some 373's..
Guest
Posts: n/a
they have a lot of common parts just laying around. mostly exhaust stuff. they can get you just about anything on order. i went there to see if the machine shop was open today. it closed 3 weeks ago so they sent me to another place. it's on indian school and 9th street.
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I have a complete disc rearend out of my 84 TA im looking to sell. It has brand new 4.10 Richmond gears which are very friendly with the overdrive, and a posi that is like brand new. Has about 5,000 miles on it. Im going to a 9-bolt. If youre interested, let me know. Im up around 75th ave. and Union Hills. Gimme a call @ 623-572-9769....Joe
Car: 4 Mopars total
BTW, i also have a posi carrier out of another 84 TA that Ill sell for $60. It came out of a car with 3.73's.
ambainb
Apr 25, 2016 09:21 PM
theshackle
Aug 23, 2015 03:49 PM
