South West Region South West regional discussion board.
MAF needed ASAP
Old Jul 21, 2009 | 04:26 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
MAF needed ASAP
Lookin for a MAF sensor, trying to swap my car to TPI from TBI except i forgot that we used the spare from my setup on soocrispy's GTA, pretty broke right now i could offer up like 20$ i just need to get this done, my head gaskets are going out on me and i figured if im tearing it down to the heads i might as well swap the intake
post it up if youve got an extra one ill buy it from you or you can text me 602-708-1468 -Andy
TIA
Old Jul 21, 2009 | 09:47 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Axle/Gears: 9 bolt 3:70
Re: MAF needed ASAP
I will look through my storage tomorrow. If I can find mine, you can have it.
Old Jul 23, 2009 | 01:58 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: MAF needed ASAP
cool! i really appreciate the help just let me know i had to hold off for this week turns out i need to do some work on the harness
Old Jul 27, 2009 | 07:40 PM
86_Dan_Z28's Avatar
Car: 86 Z28
Re: MAF needed ASAP
Are you still looking for a maf? I have one and I will be in the area in a couple of days.
Old Jul 27, 2009 | 08:29 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Re: MAF needed ASAP
Master_disaster, I have been looking for my MAF but have not been able to find it yet. If someone else has one you should probably snag it. I will keep looking just in case.
Old Jul 28, 2009 | 02:22 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: MAF needed ASAP
You can run without it for an indefinate amount of time. Performance won't be that great but basically the computer goes into a Speed density table. I drove with mine unhooked for a week to rule out MAF issues, and gas mileage didn't suffer either.
So while you are searching for one, you can drive the car fine without it.
Old Jul 28, 2009 | 07:34 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: MAF needed ASAP
yeah still looking, if you could hook me up with one that would be great, i had to put off the swap until i could find one, im not a fan of running my car in gimp mode even if it doesnt "hurt the gas" its obviously there for a reason so id rather have the items necessary than to just throw it together, this thing is my daily and i drive all over the valley for work
Old Oct 13, 2009 | 08:55 AM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Re: MAF needed ASAP
Did you ever get a MAF? I finally found mine if you still need it.
Old Oct 13, 2009 | 10:29 AM
ffemtm70's Avatar
Car: primered 1987 IROC-Z/28
Engine: 305 TPI HO
Axle/Gears: Lotsa slip 3.23
Re: MAF needed ASAP
I just tore down my motor...I am going from TPI to carbed...so I have planty of TPI stuff if you are still looking...including the MAF
Old Oct 15, 2009 | 02:04 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: MAF needed ASAP
nah i got one off soocrispy's GTA, we suspected it to be bad when we rebuilt his motor but we also replaced his burn off relay at the same time so it should be good, if not ill let you guys know
Old Oct 15, 2009 | 02:09 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: MAF needed ASAP
Its so much better NO electronics. Go with the Accel Distributor with vacuum modulator. What i did and love it. Basically everythign on my car is either mechanical like choke temp,oil.
Old Oct 15, 2009 | 05:32 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: MAF needed ASAP
been there...done that... thats why i hocked my second gen, i like computer controls better than mechanical, ease of use IMO
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
