South West Region South West regional discussion board.
Need 9 bolt backing plates
Old Dec 5, 2010 | 07:38 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Axle/Gears: 9 bolt 3:70
Does anybody out there have a set of backing plates for a 9 bolt diff with disc brakes? I need a set to put the rear end back under my car. Please let me know if you know where I can get some.
Old Dec 5, 2010 | 08:58 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Need 9 bolt backing plates
I think these are the stock sizes... http://flynbye.com/catalog/i31.html
Ed also carries them for larger brake conversions too.
You could try your local GM but I doubt they have them.
I don't know about other places, but be prepared to explain to people that you didn't miscount and it's actually a 9 bolt not a 10 bolt. I had Summit Racing Tech try to sell me a 10 bolt ring and pinion for about 20 minutes repeatedly telling me I must have miscounted the bolts on the pumpkin.
Old Dec 14, 2010 | 04:32 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Iron or Aluminum calipers? I have a set for the aluminum I plan on installing on my car, so I will have a set of iron available soon. I'd get rid of the whole iron brake setup if you come get it. Let me know so I know if I need to rush on the aluminums.
Old Dec 14, 2010 | 07:28 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Yes, I need it for the iron calipers. It is not a rush.
Old Dec 15, 2010 | 09:42 AM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
i think you counted the bolts wrong.....ha ha just playing i got some if you need them i live in the area of 75th ave and mcdowell pm me if you want them
Old Dec 17, 2010 | 04:43 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
PM sent.
Old Dec 18, 2010 | 07:21 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Baer Brakes on Thomas sells them too.
Old Jan 7, 2011 | 08:52 PM
Z28IROC's Avatar
Car: 1988 IROC
Engine: 350CI
Thanks everybody, I got some from mr305.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
