Machine work to a 350 block
Car: 1989 RS CAMARO
Engine: 305 TBI
Transmission: AUTO
I just got a 350 block and I need some machine work done to this block. Can you guys please let me know of someone or somewhere that does good machine work for a reasonable price? Thanks
Machine work I'm thinking of doing?
1. bore it out 60 over
2. Hon it
3. clean the block
4. Magnaflux it
5. install pistons on rods
6. balance it
2. Hon it
3. clean the block
4. Magnaflux it
6. balance it
Re: Machine work to a 350 block
2. Hon it
3. clean the block
4. Magnaflux it
6. balance it
2. Hon it
3. clean the block
4. Magnaflux it
6. balance it
Yeah If that's the fact that needs to be.. But .60 for a sreet hot rod.. .60 over better have a good working cooling system and don't plan on sitting on the 5 to long.. my .02 from reading.. .40 sounds cool..
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You go .030" on a first rebuild, usually. .040" is a cleanup on the second rebuild if it needs it. Only go .060" as a last resort.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Car: 1989 RS CAMARO
Engine: 305 TBI
Transmission: AUTO
Originally posted by Dyno Don
And, I would only do that on an older block, not on the later ones (thin castings).
Engine: 305 TPI (LB9)
Transmission: WC T-5
Originally posted by demonchild
technically you can get any sbc past smog, however, the law says that you are not allowed to use an older than your model year casting for an engine.
Car: F-Bodys
Engine: 355
Transmission: shifting
Originally posted by drop-top IROC
Most techs wouldn't know what year an engine was anyway. You would, however, not be able to run a carb on an '89 RS. You'd have to go TBI or TPI. If the tech really knew what he was doing, he'd also be looking for centerbolt valve covers. Just some thoughts...
Car: 1988 Camaro Convertible
Engine: 355
Get a new block. Like everyone has said here .060 is way too much. I prefer not to go over .030, but like mentioned .040 is fine. Find a block that you can do .030 get some nice forged pistons and rods and be happy.
Car: 1989 RS CAMARO
Engine: 305 TBI
Transmission: AUTO
Do any of you guys know of someone with a 350 small block for sale? Let me know if you guys have one for sale or know of someone that does? Thanks
I have a 4 bolt one piece rear seal that will clean up at .040 but it is not a roller block.
Engine: 355
Originally posted by 1fsstgta
They do know the year of the blocks because of the dipstick tube. on the older blocks its located on the driverside and after 1985 it was moved to the passenger side
Car: 1989 RS CAMARO
Engine: 305 TBI
Transmission: AUTO
Originally posted by Jstcrzyengh
The only thing I have is a complete Balanced and Blueprinted block. LT4 Hot cam, TRW forged pistons, forged rods, forged crank, Moroso pan, Cloyes double roller timing set, high volume pump, ARP waveloc, Etc... Though it might be out of your price range... Also selling Super Ram and AFR 195's... As long as the price is right. Otherwise they will go into a future project.
theshackle
Mar 5, 2017 06:37 PM
