I NEED to get rid of my 91Z
I want to get rid of my car
1991 Z28 5.7 automatic 174,000 miles about 50,000 miles on re-done motor. Minor dent on driver side rear panel clearcoat is starting to peel on a couple of areas, tranny is almost gone. Has 3.73 gears, Accel intake manifold, ported heads mild cam 1.6 roller rockers, and new catalytic converters. The car was unable to pass last smog due to bad EGR and catalytic converters. Since replacement of EGR and catalytic converters the tranny started to fail and was not able to get it smogged or re-registered. The car will pass smog if tuned but I just wasn’t able to so I want to get rid of it now. Too much money for me to put into the car to make it fun again. Small tear on driver seat, no headliner, need to put the plastic interior parts back into the rear of car, the original wing on the back and hood blisters need to be put back on.
What do you guys think its worth, or if anyone is interested in a project car.
These parts are on the car now but I am going to sell separately Suerram intake and runners, 58mm BBK throttle body Accel DFI with software and piggyback harness. The manifold will stay on the car since it is port matched to the heads.
I also have another 350 block (4bolt) and PST suspension parts for the car.
I have some pics of the car.
Scott
Scott
Axle/Gears: 3.45, 3.27, 3.27
I hope you put the car on non-op status.
Lon
Lon
Car: Moving...
Engine: Running...
Transmission: Shifting...
If you are serious about selling it then I would put it back to stock form as much as possible and sell it, that also includes taking off any bolt-ons as long as you still have the stock parts. Then I would judge the value for yourself, look on both ebay and autotrader. It's worth exactly what someone will pay you for it
i have no idea of what it is worth so please could someone give me an estimate? i want to put in the for sale section.
lon
i have it on non op status
scott
lon
scott
Car: Moving...
Engine: Running...
If you put it back to stock I would say $2500 in it's current condition. if you smogged it and replaced the interior items that are missing I would say about $3000.
Car: F-Bodys
Engine: 355
Transmission: shifting
Well since the trans is fried it needs registration and smog the paint is shot the best you could get is 1500-2000 but thats pushing it with the rest of the car at almost 180000 miles
heres the info on the motor
the heads are the stock iron heads ported dont remember to what with 2.02"/1.60" valves
forged trw pistons peended rods
the cam is a compcam part number 08-302-8 grind 264HR-12 @.050" 210 intake 220 lift .480,.480 with 1.5RR duration 112deg
crane 1.6 roller rockers (was told the lift is .510 because of the different rocker ratio)
the motor was built by Superior Automitive
it was blueprinted and balanced always used synthetic after break in period
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
Originally posted by mike83z-28
Yeah your missing the two things that make the 91-92 Z's stick out.
Car: Moving...
Engine: Running...
Originally posted by Plasma-Sword
First thing I noticed. The car is missing the 91-92 Z28 spoiler and hood louvers.
Blisters - he has the louvers installed in the pics
