Southern California Area Southern California Members.
Speed density set up for trade Maf set up
Old Aug 9, 2006 | 05:26 PM
Camaroman P's Avatar
Car: 1998 Z28
Engine: 350 lt1 sued up
Transmission: 460le
I have a 91 speed density tuneport system complete with all the sensors wire harness and ecu I would like to trade for a maf system or make me a offer
Old Aug 9, 2006 | 06:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Why would you want to downgrade to a smaller MAF system?
Old Aug 9, 2006 | 06:34 PM
Car: 1998 Z28
Transmission: 460le
Well the reason why I want a maf is because it is easier to hook up into my 83 Z28 with the vats and all a much more simple hook up for me I have been trying to hook this thing up since june and I just can't get it I just hooked up a maf on my 87 and it was much easier then this speed density I just want my car to run and I am not a pro yet do you have a maf system you want to trade
Old Aug 9, 2006 | 07:26 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I'll trade you! you still have my number right?
Old Aug 10, 2006 | 01:13 AM
Car: 1998 Z28
Transmission: 460le
No I don't still have your number
do you still have all accersories maf sensor wire harness ecu distributer everything complete because I have a complete setup everything you need including painless wiring vats bypass module included if you do can you come to la this time and if you can then it's a deal
Old Aug 10, 2006 | 08:16 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Ill trade you were in L.A. are you we could do it tomarrow if you want pm me and let me know.
Old Aug 11, 2006 | 05:19 AM
Car: 1998 Z28
Transmission: 460le
I'm in Watts I could Probably do it sunday I still Need to Pull it from my car is What year is your set up I actually need a 88 or 89 set up
Old Aug 11, 2006 | 02:25 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
mine is a 89
Old Aug 11, 2006 | 05:22 PM
Car: 1998 Z28
Transmission: 460le
Originally Posted by InsaneIROC
mine is a 89
Do you wanna come out and check it out
Steve78LT
Feb 24, 2016 12:15 AM
Bert87
Aug 23, 2015 03:50 PM
perZ
Aug 15, 2015 01:17 PM
86Base
Aug 8, 2015 01:34 PM
