Southern California Area Southern California Members.
Which Cam?
Old Sep 27, 2009 | 04:25 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Which Cam?
I want the Socal advice on a cam as most of you Socal People are all smog legal. I want a cam that will give me more power, but it must be able to pass smog. I am ready to yank on the tiny Powermax 2032 and upgrade. What would give me a noticable gain? My mods are in my sig.
Old Sep 27, 2009 | 04:36 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Which Cam?
Look at some of the SoCal car's sigs. We all have to pass emissions inspections. I passed pretty easily with the Comp Cams XFI 268.
Bill
Old Sep 27, 2009 | 04:39 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
How did you pass with the HSR?
Old Sep 27, 2009 | 04:48 PM
Burnout91's Avatar
Engine: Modded L98
Re: Which Cam?
Passed with modded TPI. A functional EGR system will soon be incorporated (by me) into my HSR. I feel confident I will pass with EGR adaptation, but we'll know for sure next October- November (2010).
Bill
Old Sep 27, 2009 | 04:52 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
It still isn't 50 state legal though. I thought Holley was trying to get an EGR HSR going?
Do you think I would notice a good gain from that cam? How about the VooDoo cams?
Old Oct 2, 2009 | 01:53 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Which Cam?
Yes I think the Comp XFI268HR-113 would be great for you.
Old Oct 3, 2009 | 05:57 PM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: Which Cam?
I say Call the cam builder of your choice, give them your specs & let them rec a cam. It will come to a point of whether you want a quick street car or a fast drag car. (that passes or doesn't pass smog)
Old Oct 5, 2009 | 02:28 AM
thegooseman's Avatar
Car: 1992 RS
Re: Which Cam?
I also think the comp 268 XFI is a good choice. All the people I have seen with it on here have at least 320 hp at the wheels and pass smog. Its the one I want to use for my build, but thats quite a ways away.
Old Oct 9, 2009 | 01:44 AM
Kevin91Z's Avatar
Re: Which Cam?
I've never had good luck with any cam company that knows TPI engines. They all know either carb engines or LS1s.
Old Jun 8, 2010 | 07:47 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
So I know the xfi 268 is popular, but would it give me more power than the lpe 219? I know the 268 is a lot more popular, so I'm assuming it will give me more power. Also, what type of power increase should I see with the 219 over my powermax?
Old Jun 8, 2010 | 08:52 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Which Cam?
Are you going to do an head and manifold port work? If no, then the 219 will be fine. If yes then the 268XFI or the 280XFI will be fine.
Old Jun 8, 2010 | 08:54 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Which Cam?
How much lift will your Trickflow heads handle? There are a couple of versions available.
Old Jun 9, 2010 | 05:20 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
I planned of getting the superram ported, not so much the heads though... I might if it isn't too much.
For the version of the heads, the receipt is at home... a thousand miles away. So ill call my dad and have him get me the part number.
Old Jun 9, 2010 | 05:21 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
Old Jun 9, 2010 | 06:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
http://www.summitracing.com/parts/TFS-30400002/
I think I have these... the valve springs that came with the heads were weak and broke, so we have a stronger set of valve springs.
Old Jun 9, 2010 | 06:12 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Which Cam?
Ok, that head is limited to .540" lift. The XFI268 camshaft is rated at .570" lift with 1.6 rocker arms. So you would have to run 1.5 rocker arms if you chose that cam.
Old Jun 9, 2010 | 06:25 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
I am currently running 1.5 anyways. Perfect.
Old Jun 9, 2010 | 07:45 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: Which Cam?
Hey Bully.. where r u stationed at? The xfi cams are amazing. I am swapping out next winter also. I hate this hotcam.
Old Jun 10, 2010 | 06:32 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
I'm stuck at lackland as a 319th holdover... I'm having some issues here, pm me your number if you want to talk sometime.
Old Jun 13, 2010 | 06:26 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
How much of a power difference would there be between the two cams?
Old Jun 28, 2010 | 12:14 PM
Kevin91Z's Avatar
Re: Which Cam?
Between which two cams? I'd still recommend the XFI268. Allen had great results with it.
Old Jun 28, 2010 | 12:37 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
Between the xfi 268 and the lpe 219 cam. Is it going to be a noticable difference from my current powermax 2032?
Old Jul 6, 2010 | 11:58 AM
Kevin91Z's Avatar
Re: Which Cam?
The 2032 is 214/220, right, but only .460 lift. The XFI268 is .540 lift with 1.5 rockers, I think. And its 218/224. Yes I'd say you will notice a difference. Also, the XFI268 is about 10 years newer technology than the LPE219.
Old Oct 13, 2010 | 08:44 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
Okay, go time. Sticking with my 350 and going to have it rebuilt before I head to japan and throw it in. Going to get the heads ported, the 268 cam is what im looking at. Hows that sound?
Old Oct 18, 2010 | 09:51 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
Found out my valve springs can take up to 600 lift, and i'm using 1.5 rockers... How much of a difference from the 268 to the 280 be?
Old Oct 18, 2010 | 10:07 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Which Cam?
Big difference duration wise. Not much lift wise. Vincent is running the 280 along with a couple of others. Como can also do a 274 as the lobes are listed in the catalog. Might be a good compromise. As to lift with 1.5 rockers you don't have to worry. You will be way under .600" lift.
Old Oct 18, 2010 | 10:10 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Which Cam?
Will it pass the sniffer with a 383, 280 XFI Cam, Ported TrickFlows, Superram? That's another concern. I see alot of you with high 300's to the rear tires and passing the sniffer.
I mean I could go Scat Forged 355, but a scat forged 383 kit is only like $40 more... What would you all do Cubic inches wise?
Old Oct 18, 2010 | 11:17 PM
Guest
Guest
Posts: n/a
Re: Which Cam?
Hows your cat? If the tune is right, it can be done.
I would go with the 268. Going with a 383 instead of 355 is mostly a matter of do you want to clearance the block, if you're replacing everything else anyway.
Old Oct 19, 2010 | 12:10 PM
Kevin91Z's Avatar
Re: Which Cam?
If you're more concerned with the sniffer and gas mileage, go with the XFI268. If you want more horsepower and dont mind the additional tuning headache, go with the XFI280. Its your call.
Old Oct 19, 2010 | 05:57 PM
Car: 1992 RS
Re: Which Cam?
http://socaltpi.org/forum/viewtopic.php?f=6&t=20
I had the same questions as you. Read that thread and you should have your answers.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
