Southern California Area Southern California Members.
Mechanic/Help needed
Old May 10, 2012 | 01:16 AM
jessc50's Avatar
Car: 88 supercharge Iroc Z,
Anybody willing to come help me diagnose/fix my camaro or know of a good mechanic that will come to my house?
Symptoms: car turns on after a few seconds it dies out, then it wont turn back on.
I want to get my iroc back on the streets!!!
Old May 10, 2012 | 01:22 AM
Guest
Guest
Posts: n/a
Re: Mechanic/Help needed
Do you have a check engine light on? If so you need to learn how to check the codes. My first thought is a mass air flow sensor.
Old May 10, 2012 | 01:25 AM
jessc50's Avatar
Yeah I do if I recall correctly it gives me code 12. I tried disconecting the maf and running it but it does the same thing.
Old May 10, 2012 | 05:09 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
can you keep it running if you throttle it? try holding the key on position?
Old May 10, 2012 | 08:19 AM
jessc50's Avatar
I'll give that a try
Old May 10, 2012 | 10:09 AM
Guest
Guest
Posts: n/a
Code 12 is ecu or ecu code error. remove your ecu unplug your battery and remove the ecu. take out the prom. install the prom back plug in the ecu an plug the battery back an try to start the car.
Old May 10, 2012 | 02:11 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Wrong..code 12 means the ecm is communicating. Check spark and fuel.
Old May 10, 2012 | 02:41 PM
rock861261's Avatar
Sounds likes vats to me... you start it and it runs for 10 secs then dies... after it dies turn the key to on then check if the security light is on... also check if it will start after 5 mins
Old May 10, 2012 | 02:58 PM
Guest
Guest
Posts: n/a
Oh ok from what I reviewed I guess it was wrong info or I missed something.. So no code for maf so that's good..
Old May 10, 2012 | 06:32 PM
jessc50's Avatar
Thanks guys ill try that and hopefully I could keep it on for longer than a few seconds
Old May 11, 2012 | 06:14 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
If it's vats, I would imagine the car wouldn't fire in the first place.
First of all, what year/engine? Is this the car you have listed in your profile?
I had a similar problem with a 91 formula. Turned out to be computer related: As mentioned above, see if you can get another computer/chip from a car with the same engine/trans combination, plug that in, and give it a shot.
Good luck.
Old May 12, 2012 | 04:28 PM
jessc50's Avatar
So I started working on it today and it wouldn't start at all. I took off the cpu/prom tried to start it and it still wouldn't start. So I'm thinking it could be vats
Yeah its a 88 iroc 5.7
Old May 12, 2012 | 04:39 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Check your key, no pill, no VATS (pill, little black button on the key)
You could always tow it to me.
Old May 12, 2012 | 05:01 PM
jessc50's Avatar
Well that rules out vats.
If I can't figure it out I would have no other choice.
Old May 12, 2012 | 08:57 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
rent a 2 wheel trailer, theres a place in lynwood i believe its 55 bucks for a day, and take it to Don. Could be a number of things wrong.
Old May 12, 2012 | 09:11 PM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
Same thing happened to mine it would start after a few cranks run for about 5-10 seconds and you couldnt start it back up for a good two hours. It happened to need a fuel pump.
jessc50's Avatar
I have AAA taking it there is not the issue. The problem is that its currently non-op and it needs a gold certifited smog check, can you also fix it so it could pass smog don? I also need to know about how much it is to fix to see if I have enough money. I don't want to tow it and then have to tow it back because I can't afford to get it fixed. If I take it to don I want to come out of his shop track ready. lol (at least running solid)
Old May 12, 2012 | 09:14 PM
jessc50's Avatar
I'll check the fuel pump/fuel pressure tomorrow see if that's the issue.
Thanks for the input
Old May 20, 2012 | 05:56 PM
jessc50's Avatar
It might be the fuel pump I used the aldl link to check it and I can't hear it turn on. The. Fuse is good is there any other thing I could check to make sure its that before trying to replace it?
Old May 20, 2012 | 08:12 PM
N_da_Mood's Avatar
Get a fuel pressure gauge and hook it up to the fuel rail and see what the pressure is reading.
Old May 20, 2012 | 08:36 PM
Dyno Don's Avatar
You can unplug the relay and jump the two end wires, that will make the pump run if it will. (orange & Tan) The fuel pump relay is the square one.
As far as cost....that is hard to say until we know what it is.
Old May 21, 2012 | 07:25 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
How long have you owned this car, and did you get it with the supercharger or did you install it. What kind of power does it make, when it's running?
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
