My Car Passed Smog Today at a Star Station
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
With the new cats it passed. They looked at the headers and saw the air tubes after I told them they were SLP headers. They asked for the bar code for them. Of course I didn't have it but they went on anyway and test it. They didn't look under the car nor pinch off the air tube that goes to the canister. Here are the results.
Transmission: 5-Speed Manual
Re: My Car Passed Smog Today at a Star Station
Is There a Cutoff Year When Cars Reach A Certain Age They No Longer Require An Emission Test In CA? Out Here When They Reach 20 Years It's No Longer Required.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I should rent that motor to others that need to pass the test.
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
dang, that passed almost as clean as my honda!
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
Congrats vincent..
I failed my smog on Saturday. Over by 5 hydrocarbons at the 15 mph test. They were about to give me crap about my SLP headers until I showed them the C.A.R.B. label under the hood that SLP sent me. I don't know about the rest of you but have you ever got any mess from the smog guys that the fuel filler pipe won't allow their own caps to fit for some pressure test? They were insisting that mine was worn or I replaced it. I told them it was not worn and that my new stant fuel cap fits perfectly. $50 to be told that I failed.
Before I go back, i'm going to remove my EGR, carb and used these engine cleaning brushes I ordered from Summit and try to clean out some carbon from the intake manifold passages.
I did it years ago with a long piece of clothes hangar wire and a vacuum cleaner which worked great. Using the brushes this time as to not mess up the intake manifold. Hopefully it will do the job again.
Car: 1991 Camaro RS
Engine: L98 350 TPI
passed mine too on saturday... surprised the hell outta me...
looks like my limits are quite a bit lower than yours... gotta love LA county... :/
(more-or-less) stock L98, L03 manifolds, single cat
Ok, now that answers one question if it matters if you car is fuel injection or not.
So if someone knows then why the "random" max numbers, please chime in. I'm sure we are all curious now.
Car: 92 CAMARO RS
Engine: 305 350 coming soon!
Axle/Gears: Stock
Not true, the operator puts in the engine size.
Car: 1991 Camaro RS
Engine: L98 350 TPI
The VIN for my car shows it to be a 5.0 TBI (RS with the V8 option)... The engine thats in it is the L98
My car was tested with a bone stock L98 5.7 with SLP 1 3/4in headers, dual cats and 3in catback. Don't go by my sig in post #1. The new California cats help big time making the car pass smog.
Well we have the same headers but I have a single 3" cat. I'm going to get a new one before I go back and replace the O2 sensor just to be safe. I have have screwed it up when I seafoamed the car a bit back now that I think about it.
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
db057
08-11-2015 10:11 PM
