Southern California Area Southern California Members.
Release the secrets of your engine build
Old Jul 23, 2013 | 06:11 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Transmission: 700hp 700r4
Axle/Gears: 3:45
Well I thought this be interesting or cool an let it out.
What were talking is what actually what did you do to your 3rdgens motor. Id like to see a new 2013 info let out there if you all like to explain your engine lay out. What are those special touches that you have done. Seems there is a Dyno Video of all these cars now in the 400+ range so lets be fair for any new comers to hear about your build. Just try to be exact with info, may provide links an actual part orders #'s.. Don an Kevin are a big help to this info if they feel sure they want to help in anyway.
The ones building there engine now like Vincent is ok to explain his current build. It only takes one part you have on order to mention your next current combo.
If your stock let's hear that also..
We don't get to see your full sig due to the limit an there are people like myself that don't attend any functions at this time.
Retired Golden State 3rd Gen Member.
Old Jul 23, 2013 | 06:39 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Release the secrets of your engine build
355 Flat tops, TRFlow heads, SLP siameze, edelbrock lower accel 29lbs injectors 58 mm TB headers Comp HR cam 286 286 53o lift magnum rollers, Borla exhaust and Hypertech chip, also have electric fans that run all the time edelbrock water pump and some other stuff not really performance related.
Old Jul 23, 2013 | 06:45 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
No cat back info flex plate to header more less crate an everything above.
Why would you have a Hypertech chip?
Sounds like a nice 355 to start..
Old Jul 23, 2013 | 06:46 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
.30 Vortec 4 bolt main Block. Old school Gm 400 crankshaft 5.7 Gm Rods Forged Flat Top pistons two valve relief. 10.6.21 compression Mallory balance for 350 balancer, 062 Vortec Ported heads Manley springs retainers an guide plates 3/8 studs roller tip rockers. Dont know about the push rod length ZZ4 cam. Scoggin Vortec Tpi base manifold lightly ported,counter sunk clearance for SR. Chromed Honed 92 Super Ram,58mm Lingenfelter Tb. 30lb Svt Injectors,Paxton afpr, Msd coil, Edel.Alum water pump. Hughes external balance 153 flex plate 2800 Toys Stall. Swap 7730 ecu. Chromed center bolt valve covers. Stock Radiator with large trans cooler higher gvt weight. 160 thermostat lower degree fan switch. Hitachi racing starter. 1 3/4 Custom Slp headers Hi Rise vette egr.
My most important mod is the Honed Super Ram with a Large Ram Air to a Lingenfelter 1000cfm tb.
1/8 8.0 deep staged
389rwhp 442rwtq Dyno Jet Dfi gen6
Accel base Manifold on order I'll submit my new engine combo soon as I can.
Ok Im finished with my new combo coming out seven months hopefully
Afr 195 Elem. 65cc My cost 1,500 heat riser, vette egr
Eagle crank an Eagle I beam rods
Lingenfelter 219/219 .560 112 349.0
Crane gold race rockers 1.6 3/8 non self aligning 296.00
Accel base manifold on order.
Manley pushrods
Thats it for the new combo.
rebuild Alum edel. water pump 75.00
Old Jul 24, 2013 | 12:18 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
The Short Block:
4-bolt main roller Vortec "880 casting #
TRW forged pistons .030 over (357cu. in.)
ZZ4 powdered metal rods
Cast crank offset ground
.020 deck height
Compression 10.6/1
The Heads:
Edelbrock E-tec 200's 90989 #
Fully ported by "Jerrywho"
Flow #'s 270/218 w/o pipe
Milled to 60 CC's
Dual springs good to .600 lift 135/360 pressure #'s
With 10 degree locks.
Camshaft:
Crower cam 225/232 114 LSA (installed on 110* intake centerline)
Lift .585 intake .550 Exhaust
Roller rockers 1.65 intake/ 1.5 Exhaust
Cloyes double roller chain
Melling 55A oil pump
Manley head bolts and washers
Genuine Chevrolet valve covers
Tuned on Dyno by Kevin
Dyno Don headers to dual cats to 3" cat back Magnaflow muffler.
LS1 brakes on all 4 wheels
Old Jul 25, 2013 | 10:12 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Stock L98 with air foil!!!
Lol, and some minor MSD ignition (cap, rotor, coil), ACCEL 8mm wires, K&N flats, gutted airbox, 26# LS1 injectors, tuned by Kevin
Nothing special here
Old Jul 25, 2013 | 11:37 AM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
383 ci edelbrock performer heads 2.02 1.60 , crane cam, holley double pumper, dyno dons, no cats, borla 3" tuneable exhaust..bowtie overdrives 700r4..Currie 9 inch..all spohn tubular spherical rod ended chassis parts including k-member
Old Jul 25, 2013 | 02:17 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Ringo234 Are you making the same power as Don when he had the E Tec's? Does he have those numbers of that combo? Interesting to know.
Old Jul 25, 2013 | 04:14 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Still waiting for a lot more builds fellows. Allen your in the lead let's hear what's working for you.
For what it seems you got a Lsx coming after you an Vincent with a 388ci. Anybody else up top? Don's where Vincent used to be 1/4 times, have not seen the Vid in awhile not sure if Don beat him, but you seen Don really raised the car almost lifted off the ground. Wow what was the reaction time on that!
As for me Im not going to talk about my seven month plan or where I'll be power wise for sure but the new combo Im thinking it's going to be pretty good. And that is going to be a good day when it's finished. Got my Accel base coming, I hear it's flow is up there high so I may not even need to hone it but port match The SR Runers.
I asked Gene how do I keep up with Vincent an he said what it will be is a Lingenfelter cam. Not sure on the 219/219 but maybe something with same lift but higher duration.
Old Jul 25, 2013 | 07:17 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Stock drop in 02 ls1 t56 driver mod, cai, exhaust, tuned 3:42s and hurting people's feelings .
Old Jul 25, 2013 | 10:37 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
no mines auto using stock throttle body only have 3" intake tube. I'm making 350 RWHP. In case your not aware that is Don's long block.
wolverine350r's Avatar
Car: 91 TA WS6
Transmission: Auto :(
Copy...Paste...
Old Jul 26, 2013 | 12:01 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Ahh come on your not hurting nobodys feelings
Old Jul 26, 2013 | 12:04 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Oh it is.. You have a good starting point there. You can still make power with auto. I did.. Did you not get Don's 1 3/4 headers yet? You didnt mention headers?
Old Jul 26, 2013 | 12:54 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
TPI Vs. LSx in 3... 2... 1...
Old Jul 26, 2013 | 01:06 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
^^^^ lmao
Old Jul 26, 2013 | 01:14 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Well mite of well since im here posting
355 ci flat tapplet block
mid cam
with 083 tpi heads with work done to them
all with a carburetor on top of it (all factory, not that aftermarket bs)
also behind a T5
Old Jul 26, 2013 | 01:29 PM
LS/TPI/turbo hybrid with 22:1 comp.ratio, runs on 87 octane . Forged everything,MS engine management . all this mated to a bullet proof power glide trans . I run negative 7's on the quarter mile . Had to stop these runs due to tires not lasting more than one pass . I'm currently working with goodyear to develop a tire strong enough to withstand all this power, that and the NHRA came down on me hard . They said if i went any faster i could create a black hole that would destroy the earth and that they saw my car as a liability . So, yeah that's my setup .
Old Jul 26, 2013 | 01:35 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Those are some secrets you shouldnt be releasing..lol
Old Jul 26, 2013 | 01:46 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
LOL!!!!
Old Jul 26, 2013 | 02:01 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
Coming from the guy who was continuously pm me about ls1s
Old Jul 26, 2013 | 06:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
No secrets with my car. It is well documented in the pages of Thirdgen.Org.
Old Jul 26, 2013 | 09:37 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
I just need to know some basics. Ya know I gotta tell em what parts they. Need to beat my Tpi Z.. J/K No seriously it's to learn new things.
Old Jul 26, 2013 | 09:39 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Ok Allen that's a long enough SIG. Thanks still using the first Injection? Intake?
Old Jul 27, 2013 | 02:07 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
did you not read my post or my signature.
Old Jul 27, 2013 | 10:16 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Since small block Chevy's have been King for so many years,
Yeah, I guess that would hurt to think you had one and couldn't make it run.
Gosh, just about anybody can make a "Small Block Chevy" run.
Some had to switch to something else to stop hurting.
And you must be hurting.... to keep trash talking.
If that's not what you meant, I'm sorry, I apologize.
Old Jul 27, 2013 | 06:18 PM
Z28FAST1's Avatar
^^^I sense feelings have been hurt.
My build: Stock cube GM LS, stock GM internals (crank, pistons, rods etc), stock GM valve-train(except for springs), mild off-the shelf cam + built in driveway mod + powered by haters
Old Jul 28, 2013 | 12:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The only hurt feelings I see is from you guys who cannot understand why we don't kneel down and kiss your feet for having an LSx in your car.
We're happy doing our own thing and accomplishing our own goals with our thirdgens. Just like you're doing your thing with yours. Its all thirdgen power to me.
Old Jul 28, 2013 | 11:21 AM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Built Elis Juan forged by Mjölnir putting out 9000 hp and 10,567 ft lbs of torque. All on pump gas and pulling wheelies on the freeway at 120 mph with street tires! I'll take my secrets to the grave!
Old Jul 28, 2013 | 12:29 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
It actually started when mikey asked about the swap and your dad put him down for the idea and called ls swap cars bastardized. But! That's neither here nor there and was truly the inspiration for my swap. So thank you for that.
Back to topic, bone stock ls1 t56 here. No secrets, yet.
Old Jul 28, 2013 | 12:45 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Ya sorry of course you have headers, you have Vette Egr just like myself.
Old Jul 28, 2013 | 12:56 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Justin you all act different an bring up weird things you say that's all. Saying hurting peoples feelings wasnt the topic. It's a pencil pusher saying in a way. Ok from Don's understanding about this label Basterized, all he knows is a younger generation going the Lsx route an not the old school muscle. Your put into a Mustang catergory in a sorta way even being Chevy and there is always going to be a grudge. It's like you put a Mustang engine in a Camaro because you put a not so great of a year Camaro car an engine into your thirdgen. If it was a modified 5thgen then that's a car an motor that is something to brag about an make comments like hurting peoples feelings.
So will just drift back on topic.
Old Jul 28, 2013 | 02:03 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
I couldn't get past the first two sentences. Don't put me in any group my words are my words, in fact this is my first post in socal section in a while.
And to clarify, yes I realize the tpi lsx debate has been beat to death. I don't think Fidel was talking about anyone in particular. But someone here not only thought the shoes fit, they laced those b*tches up and wore them.
Old Jul 28, 2013 | 02:33 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
delete that there.. Sorry Justin
Old Jul 28, 2013 | 03:18 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
So your making all these low Et's high mph with no headers, with gears changed? And secret hp numbers because of what? That sounds like trying to cut in line to me.
Old Jul 28, 2013 | 04:03 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
See what you did was this, Hey Jim go pull me that ls1 out of that wrecker an put it in my 82-92 Chevy. And that's all it is.
That is untrue. I've built my camaro from the ground up since 07. There isn't a single bolt I haven't touched on it. I didn't just go and seek a swap it was never planned. I happened to be blessed with a deal I couldn't pass up on a donor. I did all work myself.
I don't consider myself part of any lsx tpi crowd. When there is all this debate I'm just laughing about it. No hard feelings here.
Old Jul 28, 2013 | 04:47 PM
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Ok so there's your story. I have turned bolts too. I don't take the credit the car gives me the credit an the numbers to prove it. 100hp more will give you something to talk about then. I understand the reality but a never planned thing doesnt mean anything else besides you got a good deal an you could not spend the money we have spent on our Tpi builds. A lot of people do way more work than us. Ha Gene you should see that thing put together.
Old Jul 28, 2013 | 06:09 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Must be nice
Old Jul 28, 2013 | 06:10 PM
Z28FAST1's Avatar
It's kinda like this, We tpi crowd an that includes me as I have a lot. I have a whole list of these performance parts from my starter to my rear stroker crank adapter on my 400 crank. We have this full list an the Lsx crowd is mild cam an thats all
In time Im going to handle alot of Tpi an Lsx at the dyno
because I seen there numbers now Im not saying Mini Ram because I don't know what that is going to come out to be an if I can match that
Is it my fault that you paid $$$$ for every aftermarket performance part available while I took advantage of GM's stock LS parts to go faster?
In time...? You've been talking about this stroked TPI engine for 3 years and it hasn't made it to the track once?
Your thread states "engine build" that's why I posted the particulars of my engine and not my drivetrain, exhaust, interior or exterior mods.
Who cares what you guys have spent on your TPI builds.
Old Jul 28, 2013 | 10:11 PM
Dyno Don's Avatar
By the same token ...who cares about your swaps.
You don't get "Respect around here...you earn "IT".
Old Jul 28, 2013 | 10:17 PM
Kevin91Z's Avatar
Your talking about Don, Me? Or you don't want put in a lsx category because what comes with it? It's kinda like this, We tpi crowd an that includes me as I have a lot.
No, Branden, you are not part of this TPI crowd. You are on your own. Don't speak for us.
Old Jul 29, 2013 | 07:50 AM
  #42
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
Branden, I've organized another 3rd gen shootout for August 29th. I will comp your fuel, entry fee, and driver fee so you can come out and put everyone on notice with that world class stroker of yours...
But wait, let me guess... you've hung up the old drag racing gloves and don't race anymore...?
Old Jul 29, 2013 | 10:43 AM
  #43
actarnoff's Avatar
Engine: 355 TPI
I'd contribute, I would *love* to see that.
Old Jul 29, 2013 | 11:22 AM
  #44
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
That's very nice Mike but that's a good one. I see once you all know that I have some engine plans this just engine build topic turns out to be ***** an nuts. And goes down hill once a Lsx is mentioned.
I asked for your help with these people and you didnt write back. A year ago you did help an I took your advice, I was gone for a full year. This post here is what I like doing. I cant control what everyone has or doesnt or what I have. I have never said that I was going to be on top an 2007 never said I would be on top at the strip. I was on top with Dyno results an that's it. It is not my fault that nobody is above 442rwtq yet. And I earned it because I paid the Boo Koo money for it. I dont have a forged crank an 1k rods. 700.00 roller rockers 2k heads and all that good stuff like some have. Looks like only a Lsx can compete with a Dart Block an Im sure a full built 4l60e with a Yank 4,000 stall! So it's proof there that I dont have a World Class Stroker. As there is nothing I can do right now to compete with that.
I told you I wanted to start learning Auto Cross and not tear up my car at the strip. Esp with parts getting a lil rare. Who's going to have 3:45 gears or the unit if it breaks? I just had to replace a 500 plus Lingenfelter throttle body with a new one just because a spring broke. And there a little hard to find for under that. And I found one.
I tell you what when Gene is done with the build an Bds an another tuner is done with the Dyno I will come to the track. If the car is running on the street I will drag myself an Gene with a trailer an pay for it win or lose. Our one focus is Vincent an there's nobody else. And that's just to be sure were performing the same.
So never had no Racing gloves you were there. It was just the first runs of my life.
So go out there do your event an do what you do.
Old Jul 29, 2013 | 11:33 AM
  #45
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
I'll get you some pictures where my car is right now. Oh wait telling is so easy.
Look No Steering. Im working 12 hour days over an over an over. 80 hours in a week an Im going back to bed before I go to work again. UGHHHH Jokers.
Why is the thread turning into a Racing subject that's not what it was, I just mentioned it to Lsx bc I knew something was missing seriously guys. Watch nobody else is going to post what I wanted to see what every one had! One more day of my new post an it's being deleted... Im not fighting all these people again.
Don won't post his Kevin won't..Once I tell Justin hey don't let these people run you out of here there not running me out. An all mighty Kevin says Im not a part of the Tpi crowd because he has started a Tpi club alone. Many people wanted other clubs an Kevin shot them down. An he has a Tpi club Now! I don't like Kevins club never did I went to a couple meetings an that was it and it was basically because Don's build, That was years ago when Dean came. Im not a part of anything so you don't have to throw it in my face. I told you all Lsx will eat you all up an you know it so get the grease out of your ears! You want to know the truth what Gene says. Peanut motors all you have an all you Do! Just so they get back in line an get more work.
Old Jul 29, 2013 | 12:26 PM
  #46
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
No Kevin Im not a part of your Illegal Tpi's! Im Super Ram. Own it an proud of it while you complain about them. Complain of a man spending One hour an lash everything in one hour an running!
Old Jul 29, 2013 | 12:31 PM
  #47
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
They didnt have Lsx swaps back in 2001-2007.
Ok of course ya Im in the making of first getting my Infiniti back on the road I just bought last year, an yes Gene an myself are going to build the 383ci.
Headers are a part of the engine. If you have a part not engine wise an is working for you like say your gears let us know. We can go off main topic.
I did not do this to fight. my hands are behind my back. Some one else is doing that!
Ya who cares the money is gone already!
Old Jul 29, 2013 | 01:03 PM
  #48
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Branden, please stop trying to drag Gene into your banter and putting words into his mouth.
I stopped by Gene's new shop a couple weeks ago just say say hello and see what his new shop looked like. Gene is a good guy who busts his *** to stay ahead of the performance curve and is a wonderful mechanic and at extremely fair price.
So for you to try and make your words his on this board is to systematically undo everything he has works so hard for over the years. For those that know Gene, know that you are full of **** and that he would never place himself above or ahead of TPI or LSX because it is completely out of his character to do so.
For those that don't know Gene, you are destroying the opportunity for him to capture new business through this message board.
Not cool man. ...and why? So you can have a someone in your proverbial corner that can never affirm or contest the things that you are saying he said?
Seriously bro, you need to stop...
Old Jul 29, 2013 | 01:08 PM
  #49
IrocZ442's Avatar
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
Mikey look some one just pm me a Vet that i directed him towards Gene. No one here would help him.
WTH are you talking about. Peanuts is what Gene told me an that's me included!
None of you know Gene like I do! Gene knows of all this B.S here you all do. It's not me why he doesnt come here. It's probably another reason. Gene has helped me through thick an thin. And I have done the same for him! You waltz in there with your understanding of what you understand of mechanics an shoot me down. Like Im ruining it for him! These people here are for Don to build there cars.And some been talking a lot of smack on Gene a year ago.
I mentioned Gene an myself are going to build my 383ci our way. That's it.I dont need nobody on my side. I come here to this post just to learn combos an I already knew this post would go south. All because some people here give Lsx a real hard time! Gene told me an taught me quick about Lsx an he tell you again Tpi cant hang with Lsx builds.
So you want to see me race in the future well I tell you the car will sit in the parking lot till Vincent is ready to run! We will be finished with each other that day!
You guys just hate it because I tell Don an Kevin the truth. You just cant see people that look through most of you an see reality what Gene really could do for them. Gene already an I told you before it's working.. Getting people that want to get into the battle well Mike the pro of the industry that's what gets them started.
Old Jul 29, 2013 | 01:25 PM
  #50
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Branden, stop.
All of this senseless interaction with what purpose!? To further establish yourself as a non-authority on TPI, LSX, 383's, etc?
You have what you have, I have what I have, and everyone else has what they have! Continuing to solicit people for information on their individual builds is nothing more than a pathetic attempt and generating ANY interaction with you (albeit negative) so that you feel relevant or perhaps enlightened?
Please explain your undying self-deprecating desire to continue to have people tell you that they don't want you or that you are an idiot? Why do you continuously place yourself on a pedestal only to be knocked off repeatedly by others far more knowledgeable than you claim to be?
Please help me understand why you do this to yourself!?!?!?!
