sway bar end-links.
Old Apr 26, 2002 | 11:52 AM
86maro305's Avatar
sway bar end-links.
i can't get the end-links off my car. is there some secret or am i just stupid. help me out
Old Apr 26, 2002 | 02:34 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
when i did mine, i ended up breaking 2 of the bolts, i assume you have new endlink hardware (if you don't get some) and then just get a wrench you can get some good leverage with, and wrench on it till it breaks. this is pretty common that they break, because the nut sorta gets perminetly attaced.
you could try some penetrating lube, and see if that does the trick.
Old Apr 26, 2002 | 03:45 PM
vjo90RS8's Avatar
Car: 2002 Z28
you need to keep the top nut stationary while you unscrew the bottom, it will take some work because of those rubber spacers but will eventually come off. I had no trouble getting mine off a few weeks ago.
Old Apr 26, 2002 | 05:11 PM
Chet's Avatar
Car: GTA
Be a man and just use a hacksaw
Old Apr 26, 2002 | 10:06 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Umm...
I used a torch to heat them up and that really helped, I changed all four of mine. I broke teh front to and used the torch for the rear. It can be messy but it is not much, it comes off pretty easy.
Breaking them should be the easiest thing to do.
Old Apr 27, 2002 | 07:59 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
when I recently did mine, one side came off (but I wouldn't have used them again) and the other side I had to cut off.
contact Guldstrand and get their kit. It's complete, poly, plated and reasonably priced.
Mike
Old Apr 27, 2002 | 01:40 PM
Beefy89's Avatar
I replaced mine 2 weeks ago,and used a sawsall to rmove them.
Got some new poly ones at Autozone for $3.99
Old Apr 27, 2002 | 07:40 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Mine were rusted beyond belief and I had to replace mine too. Just get new hardware, you'll save yourself frustration of trying to reuse the old crap.
Old Apr 27, 2002 | 07:45 PM
Buck268's Avatar
yup, like everyone says, just use some brute force and ignorance (little quote from my shot putt/discus coach) to remove the old ones, then replace with bright, new ones includng poly bushings. They are availibe from your local auto store (well, AutoZone carries em fer sure), for about 3-4 bucks a pop...
Old Apr 28, 2002 | 02:48 PM
86maro305's Avatar
so should i use a sawsall or just wrench on them till they break.
Old Apr 29, 2002 | 07:51 AM
Buck268's Avatar
Yup, just cut - or wrench - em off...
Old Apr 29, 2002 | 05:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The problem is that the thru-bolt has rusted to the center sleeve. So even if you snap the nut off, you're only freeing 1/2 of the end-link, the other will stay stuck to the bar. A hacksaw's the way to go. The front's a bit tricker; it's hard to get a saw in there. I used a cutting tip on a soldering iron to slice the end link bushings (control arm side) down one side. Then I pried the bushings off the end link, and used bolt cutters to cut the end link bolt off. Now I have air tools, and would probably use a cutoff wheel.
Make sure you lube the new end link's center bolt up with a TON of silver anti-seize to help prevent this from happening in the future!!
Old Apr 29, 2002 | 06:22 PM
ebmiller88's Avatar
Ditto, both of my sleeves were rusted to the bolt and the bolt itself was corroded to about 2/3 of it's original thickness. Also, when I reassembled my links with the new hardware, I used a ton of anti-seize, I have some stuff called Moly-cote and it's great. I use it on all nuts, bolts, etc. I got it off my submarine before I got out of the Nav.
To get my links off, I did manage to get the nut off, then just beat the hell out of the bolt and drove it out with a 4 lb. mallet.
Old Apr 29, 2002 | 08:26 PM
Buck268's Avatar
I guess I am just not that smart, as I just bust the nut head off, put the sway bar off (coarse, had to pull bar off anyways), and chissle sleeve off. And naturally, I didnt even think about anit sieze stuff!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
