Front LCA grease question....replies????
Old Apr 27, 2002 | 02:48 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I just had my lower front A-arm bushings installed by a shop and they did a great job, but I have a small concern. When they installed the new ES shells and bushings, they used some light gray colored sticky *** grease instead of a "formula 5" type white silicone (?) grease shich I know is recommended. Is this OK or should I try to get the stuff off and use another type?
Thanks....
Old Apr 27, 2002 | 07:47 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
if you had poly bushings put in, try to use the recommended grease for them. they'll last longer.
Old Apr 27, 2002 | 08:44 AM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
When i put in my bushings i used never seiz on them because i felt i would work better then most of the grease. never seiz is grey and real sticky so that is what they might have used and soo far i have not had a problem.
Old Apr 27, 2002 | 07:45 PM
ebmiller88's Avatar
It may be anit-sieze, it's just not what I'm used to. I think I'll just leave the stuff on there and use Spohn's grease when I install them. After some thought, I really don't think it will make that big a difference.
I have pics of the first part of the disassembly but I haven't put them on the web yet. I'll keep you posted.
1992rs/ss
Jan 31, 2025 05:10 PM
TheExaminer
Aug 25, 2015 07:34 PM
zayne0
Aug 24, 2015 07:22 PM
wruiz
Aug 11, 2015 02:59 PM
