will 13 in baer track kit fit stock 16 inch wheels
Old May 2, 2002 | 10:18 PM
bubafett's Avatar
Upgrading brakes.
Will the 13 inch Baer Track kit fit stock 16 inch wheels on a 91 Z28.
I will also measure with the template.
Two calls to Baer one yes one no.
TPIS catalogue lists wheels that do not fit. Mine are not listed.
Any help appreciated
Old May 3, 2002 | 07:22 AM
Intercepter's Avatar
Baer has a template you can download and use to make sure that it will fit. Here you go
http://www.baer.com/template_lists/gm_f_body.shtm
Old May 3, 2002 | 09:43 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Double check the dimension when you use the template. I did it in a rush and my rims didn't fit. A rather expensive mistake. By the way, I had the deep dish WS6 rims.
Old May 3, 2002 | 10:46 AM
urbman's Avatar
I have the pontiac 16 inch aluminum wheels (1990 )
and the 13 inch kit won't go...
The template asks for 7.72 inches from the center
of the hub to the farthest edge of the caliper
The template for the 12 inch kit indicates
that it will work but is close....
The template asks for 7.22 inches from the center
Azrael91966669
25
Jun 20, 2017 04:04 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
mustangman65_79
Aug 9, 2015 03:00 AM
