just did front brakes and car still pulls
Old May 9, 2002 | 11:54 PM
87 B4Z's Avatar
i just did front brakes on my IROC and it pulls to the right even more than it did before. i replaced the hoses, cailpers, rotors, pads and bearings and it still does it. what else could make my car do this.
Old May 10, 2002 | 12:11 AM
vjo90RS8's Avatar
Car: 2002 Z28
did u get it aligned?
Old May 10, 2002 | 12:13 AM
87 B4Z's Avatar
it only pulls while braking, whats to align after a brake job.
Old May 10, 2002 | 01:14 AM
Akshay's Avatar
First, put the proper amount of air on all tires.
Now, bleed the brakes.
Check to see if the hose doesn't have a leak anywhere. It could be the left side.
Akshay
Old May 10, 2002 | 01:27 AM
Akshay's Avatar
Akshay
Old May 10, 2002 | 09:22 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I suppose the left hard line could be clogged. Since that's the shortest and easiest to replace, you might think about it.
Old May 12, 2002 | 11:00 PM
shawn87gta's Avatar
Mine did the same thing. Replace the hoses, they collapse inside after a while.
Old May 13, 2002 | 08:39 AM
99Hawk120's Avatar
If you read his first post, he clearly states that he replaced the hoses already.
Old May 13, 2002 | 09:31 AM
TVP's Avatar
TVP
Hey ...
Under braking your wheels stop ..then all the force goes through the suspension to stop the car .. check your lower ball joints and lower A frame bushings .... then tie rods , center drag link , pitman arm , idler arm .. that's about the whole thing :\
TVP
Old May 13, 2002 | 10:03 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How bad is the pull? If it's minor, I'd say to try and re-bleed the brakes. Did you let the master cylinder run dry? When I changed my front hoses years ago, I almost let the reservoir run dry... nearly freaked out. I was watching the frontmost reservoir, then I looked at the one closest to the firewall, and it had 1/8" left of fluid in it- oops! I dove for that bottle of fluid so fast I'm surprised I didn't trip over anything on the floor.
Old May 13, 2002 | 10:21 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
You might want to check the rear brakes, since it's an IROC, and you didn't specify, you could likely have disc brakes(drum brakes not adjusted could also do it), which are known to be problematic. Try getting a nice patch of asphalt, and locking the tires for a short distance(less than 1 ft, bascially, as soon as you hear squeal) and then check the patches and see if one or more of the tires is the only one locking up, then check that wheel. Alot of times, rear brakes cause a 'pull' more than you think they would.
Old May 13, 2002 | 11:11 AM
99Hawk120's Avatar
We went through this on another thread.
Rear brakes on a live axle rear suspensioned car cannot cause a pull.
Old May 13, 2002 | 09:02 PM
britered86transam's Avatar
yeah ijsut replaced my fornt calipers and pads too, my car has a minor pull to the passenger side, should ijsut try to re-bleed?
Old May 13, 2002 | 09:49 PM
Jza's Avatar
Jza
I'd say take a look at the upper strut mounts.
Old May 14, 2002 | 08:04 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Hmm seems to be a popular problem for thirdgens. I'm going to replace all the hoses on mine with braided hoses and see if that helps. I'm afraid to drive mine in traffic because it pulls hard when I brake and I know I'm gonna wreck eventualy if I don't fix it.
Old May 14, 2002 | 08:14 AM
99Hawk120's Avatar
It is a common problem, but 90 times out of 100, replacing the hoses works, and 9 times out of 100 replacing the calipers fixes it. The original poster in this thread did all that already...
Old May 16, 2002 | 10:39 PM
BOTTLEDZ28's Avatar
Transmission: A4
you know, i had this same friggen problem on my last z. i replaced al sorts of **** an and nothing worked... then i said to myself....self, why dont you change the hose. surrer then **** it was the hose. i ended up changing them all and the car stopped 100 times better. i know you said you changed the hoses though. bleed and rebleed. thats all i can say.
Old May 17, 2002 | 11:28 AM
305RS17's Avatar
you might wanna flip-flop the front tires and see if it will pull the other way, you might have a tire seperation.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
