Proportioning Valve Differences
Old May 15, 2002 | 04:57 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
there is Prop valve #14089496 ----- 1LE
and prop valve #14089497 -------- regular 4 wheel disk
i mistaking ordered the 1LE prop valve and am using it. the problem is the front brakes seem to be most of the work(they make a moaning noise) and start to smell burnt pretty easily . system has been bled. Am i correct in assuming since the 1LE have bigger calipers, that the prop valve is designed to "proportion" even more fluid to the front than the rear as opposed to a standard 4 wheel disk setup? this causing my fronts to work harder than they are supposed to? i'm throwing ideas out here guys.. well if that is the case, what is the difference between the two valves? is it the spring that regulates pressure to the rears(the spring in the front of the valve)? or is the internal valving too different, warranting the correct prop valve be purchased? if so i will go ahead and order a replacement. well i hope some of guys here can shed some slight on this foggy subject.
Old May 15, 2002 | 09:16 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The proportioning valve on our cars is actually refered to as a "combination valve" it controls both flow and pressure.
You need to get the correct "combination valve" for your application.
Thanx,ANDYZ28
Old May 15, 2002 | 10:45 PM
Car: 1988 IROC-Z
i was afraid of that... thanks alot Andy i owe you a beer.
Old May 15, 2002 | 10:58 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You should get all the info you need in Andy's 1LE post at the top of the section.
Also, check out Daniel Burke's page for more info and more pics:
http://www.ws6transam.org/1LEbrake.html
Cameeeero
Sep 18, 2015 04:00 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
crazynights
Aug 21, 2015 06:53 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
