coil spring compressors
Old Jul 9, 2002 | 04:34 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Can anyone recommend any coil spring compressors that work well on the front springs on third gens. It must be the ones that go inside the spring through the hole in the track control arm (obviously!).
Thanks.
Andy.
Old Jul 9, 2002 | 05:12 PM
urbman's Avatar
I did this..
Old Jul 9, 2002 | 05:14 PM
urbman's Avatar
It goes like this...
Old Jul 9, 2002 | 05:15 PM
Swede's Avatar
That´s real clever idea urbman! great
Old Jul 10, 2002 | 09:41 AM
urbman's Avatar
Check out ebmillers site for another idea and a fairly
complete disassembly guide
"5inch pipe" looks good
Old Jul 10, 2002 | 03:17 PM
DM91RS's Avatar
Car: 91 RS
urbman
Kick a$$
I like it. I'll make a plate for mine now.
Thanks for the idea :hail:
Darrell
Old Jul 10, 2002 | 04:42 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Urbman:
I agree, that is a great idea! What are the metal plate dimensions? I am going to the hardware store tomorrow!
abcx09t
Old Jul 10, 2002 | 04:58 PM
Car: 91 camaro rs
Urbman.
Where did you get the compressors from?
Andy.
Old Jul 11, 2002 | 05:13 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Thanks for the plug, urbman.
Here's a pic and a link to my page:
http://photos.yahoo.com/bc/taramille...tos.yahoo.com/
Rented from AutoZone, $35 I think, and all refunded. Read the description, you'll need the pipe nipple to make it go smooth.
Ed
ebmiller88's Avatar
(Deleted)...
Old Jul 11, 2002 | 12:28 PM
urbman's Avatar
I purchased the spring compressor from a local
tool store...
Santa Fe Tool, ( I can give you the phone number or address
if that would be useful, excellent selection of speciality tools )
They are usually available from larger auto parts stores..
The dimensions are roughly ... 4x4x1/4 inches
"eb's" idea would let you skip shortening the threaded rod...
Old Jul 20, 2002 | 06:19 PM
abcx09t's Avatar
I just did my front suspension last weekend. I replaced motor mounts, tranny mount, control arm bushings, ball joints, tie rods, idler arm, tie rod connectors with Hotchkis, centerlink, Eibach springs, KYB Struts, got new alignment. It was easier to compress the coil springs ebmiller way since springs slip right out of the control arm. Need no spring compressor to install springs. Ball joint boot was not installed at shop. They said too many complaints if they get torn. So check with your shop. Paid $75 to remove spindles, ball joint and bushings and have new bushings and ball joint installed. Used 1 1/2 inch diameter copper pipe to install the ball joint boots, they are an interference fit. Otherwise, everything was pretty easy. Sorry, but never used the Urbman set up. If you are planning this upgrade, review the ebmiller websites they helped the most.
MM2Robinson
Oct 1, 2017 09:16 AM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
