Can't get rid of the shakes!
Old Jul 29, 2002 | 10:07 PM
GMmuscleman's Avatar
My car shakes and pulls to the right! I've had the front end aligned, the tires trued and balanced (twice). The only thing I can figure is that I have a bad tire, but I've had the two front ones switched and it still pulls to the right. I can't find anything unusual underneath. Any suggestions? It's getting worse.
I've checked my wheel bearings, they're good. My rotors are brand new and not warped. I'm going nuts! Help!
Old Jul 29, 2002 | 11:16 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've got a '91 with a steel D/S and I have one hell of a shimmy at 75 and higher. I'm thinking it's the shaft. Others have had this same problem. Just a thought.....
Ed
Old Jul 29, 2002 | 11:24 PM
Hehe, well, that used to be my problem about a year ago, but I had a driveshaft built for it, so I've already ruled that out.
Thanks anyway.
Old Jul 30, 2002 | 08:55 AM
ATOMonkey's Avatar
Bad tie rod ends, idler arm, or anything else in the steering is my guess. They're supposed to check that stuff when they align it, but that doesn't mean they did.
Old Jul 30, 2002 | 10:28 AM
Yeah, that's what I'm thinking. I know it's not the idler arm because they replaced it when it was aligned. My next guess is the tie rods.
Old Jul 31, 2002 | 10:39 PM
Any other ideas? I'm just trying to cover all the bases.
Old Aug 1, 2002 | 03:28 AM
ebmiller88's Avatar
Strut gone bad? I broke a shock once on my old Chevy half ton truck and the thing went everywhere.
Ed
Old Aug 1, 2002 | 08:02 AM
ATOMonkey's Avatar
along that line, the bushing that holds the top of the strut can go bad and cause the car to wonder and shake.
Old Aug 1, 2002 | 09:12 AM
Nordbert's Avatar
I would borrow a set of tires and wheels from a friend and
see if the problem was still there.
Old Aug 1, 2002 | 09:20 AM
Cool!
Thanks guys! I'll check out the struts and bushings. Ball joints too. I'll see if one of my buddies will let me borrow two wheels and tires for a few minutes too. I'm going to figure this thing out if I have to rip the whole front end off and rebuild it!
Old Aug 5, 2002 | 08:20 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Me Too
I've got the same problem on my '91 rs with tubular a-arms w/non-greasable poly bushings, Eibach sport springs, KYB shocks, poly sway bushiings, new TT2s and new tires. I haven't changed an old (72k) center link which has some play and is my first suspect. What else should I look into?
Old Aug 6, 2002 | 08:50 AM
Hmmm.....I might take a look at my center link too.
Old Aug 9, 2002 | 09:13 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Had exact same problem with 98 blazer except it wanted to go towards the left (this was about a year ago) and we took it to get new tires and alignment at a tire place that sells Goodyear. Well that didn't fix it so we took it to a Firestone place and the guy said he'd look at it for free (we used to go there all the time but went to the Goodyear place for some reason) he found out the upper and lower ball joints were lookin really bad so they replaced them (under warranty) for free since the Chevy dealer down the road has them do some of their warranty work. Anyhow check those joints I guarantee that's the problem. Well it could be something else I suppose but that's what my prob was
Old Aug 9, 2002 | 10:27 PM
Thanks man! I'll check them out.
Old Aug 9, 2002 | 10:43 PM
camaro89dude's Avatar
My car had that problem and something crazy had happened to me. One of the bolts had come loose on my A-frame (can't think of the other name for it right now), which caused many a vibration while slowing/stopping. I basically had to slam on the brakes to keep from vibrating so hard. Eventually that bolt fell out in the middle of the road and I realized what it was. So make sure you have all your bolts in there.
92-Formula
Dec 12, 2015 10:34 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
