how hard is it to lower the rear end
Old Aug 1, 2002 | 10:38 PM
fattie92's Avatar
i need to lower my rear end so i can put my air bags in the springs. how hard is this to do, any tips to help me out any??
Old Aug 1, 2002 | 11:25 PM
MdFormula350's Avatar
put jack stands on the rear frame rails so that the rear is just floating off the ground, after that i guess u need to take the lower bolts out that hold the shocks to the rear end. after that take out the bolts of the lower control arms that also connect to the rear end. before you start taking the bolts out i would put a jack under the rear end housing and hold it in place and once the bolts are out, just lower the rear ned slowly untill the rear springs are loose enough to take out.
Old Aug 2, 2002 | 08:08 AM
fattie92's Avatar
yeah thats what i figured, didnt know if there were any tips on doing it, or any problem areas. so then this is a pretty straight forward job then.. thanks for the help!
Old Aug 2, 2002 | 09:23 AM
yeah you just have to be careful because you working with heavy stuff.
Old Aug 2, 2002 | 09:24 AM
yeah you just have to be careful because your working with heavy stuff.
yeah its a fairly easy job and very straight forward.
your welcome for the help.
Old Aug 2, 2002 | 12:01 PM
fattie92's Avatar
can i do it with the tires on? or do they have to come off? also, where do you think i should put the valve for the airbags?
Old Aug 2, 2002 | 12:36 PM
i am not sure, i never had airbage before, but i would say that u have the vavle so where u can adjust it if needed.
Old Aug 2, 2002 | 12:46 PM
fattie92's Avatar
i was thinking about putting the valve in the wheelwell on the back wall...its a thin plastic so it will be nice and easy
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
