difference between 9 bolt and 10 bolt PBR mounting brackets?
Old Aug 27, 2002 | 09:22 PM
breathment's Avatar
i just bought a rear 89+ PBR brake setup.. but i don't have it yet. and im wondering, is there a difference in like 9 bolt and 10 bolt setups?? or any other differences that might screw me up?? i forgot to ask what it came off...
Attached Thumbnails difference between 9 bolt and 10 bolt PBR mounting brackets?-rearbrak.jpg
Old Aug 27, 2002 | 11:01 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
FYI, that pick is of the older rear disc setup, not the PBR ones.
I think there are some threads in the archives on this and I *think* you can modify the axle tube flanges on the 9 bolt to accept the PBR brake caliper mounting brackets.... Not sure though...
Old Aug 27, 2002 | 11:12 PM
breathment's Avatar
AHH how so??? if i bought those and they AREN"T the rights ones....
Old Aug 27, 2002 | 11:29 PM
Matt87GTA's Avatar
Look at the pads.... Dead giveaway right there, those are the same pads that the stock non-1LE front brakes use which is what the older rear discs utilized as well..... I would get a hold of the seller at once and verify if that is the pic.....
Old Aug 28, 2002 | 12:13 AM
breathment's Avatar
ya i emailed him.. And i looked at some other pictures of the 89+ rear brakes, and i saw the differences... oh well i thought $150 was a little too cheap!!
thanks for catching that for me!!!!!!!
Old Aug 28, 2002 | 10:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yeah, definitely not the PBRs... you got hosed!!!!
FYI, the PBR calipers themselves are aluminum and have fins on them; and they float inside a bracket/carrier thing. The backing plates are much smaller than those in the pic.
Old Aug 28, 2002 | 11:37 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yeah, you almost got screwed there. I've seen a lot of people selling those setups on ebay and saying they're "1LE" and 89-up, which they are not.
If anyone needs to see what the PBRs /1LEs look like, check out my rebuild page here:
http://photos.yahoo.com/taramiller72
Ed
Old Aug 28, 2002 | 12:39 PM
german-motorsport's Avatar
This is how a "real" 89 up set up looks like!
"REAL" : cause this is a Baer setup!
A bit higher in price but new and no need to run around hunting for parts .......!
RB 83 L69 is right someone busted you!
If you need info feel free to email us !
By the way our infos are free!!!!!!!!!!!!!!
Attached Thumbnails difference between 9 bolt and 10 bolt PBR mounting brackets?-dscf1676.jpg
Old Aug 28, 2002 | 01:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's a Baer setup then it's aftermarket, so how can it be a "REAL" 89 up setup?
Old Aug 28, 2002 | 02:51 PM
Mein lieber Apeiron!
Wortschneiderei...............oder gelabber!
Plssssssssssssss real was set in " ....." !!!!!!!!!!!!!!!!!!!
just to let breathment see what everybody is talkin about!!!!!!!
Old Aug 29, 2002 | 08:39 AM
ebmiller88's Avatar
Here's a shot of mine, '89 GM:
Attached Thumbnails difference between 9 bolt and 10 bolt PBR mounting brackets?-all-set-1-.jpg
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Elliswon
Aug 10, 2015 12:33 PM
