best way to get the front wheels up
Old Sep 14, 2002 | 03:08 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
ok what is the best suspension set up to use to get the front wheels to pull up off the ground......? please help wanna yank them up.....
Old Sep 14, 2002 | 07:03 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
TORQUE!!!!!!!!!!!!! and lots of it.
Old Sep 14, 2002 | 07:57 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
talk to ed maher on this board he has a reletivley stock 305 tpi a4 vert and he yanks the wheels on launch....its gonna be hard to do witha stick but an auto is easier....and yes TORQUE
Old Sep 14, 2002 | 08:43 PM
AFrikanGoodTime's Avatar
Color me puzzled with this comment. Last I checked you could hold revs up as high as you want with a clutch/stick? But not an auto. I'll assume this was a typo.
Old Sep 14, 2002 | 11:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
spray a 125 shot right off the tree with slicks, and a high stall.
Old Sep 15, 2002 | 02:08 PM
86IROCTHD's Avatar
Car: 88 Trans Am
nitrous
yea i have tried the 125 dry shot off the line with 28 inch tall slicks goes ape wild off the line but cant get it up.... stock stall and tranny and 3.08 gears
Old Sep 16, 2002 | 02:02 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Stick a few 50lb bags of cement in your hatch in the well
Old Sep 16, 2002 | 06:32 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Get eibach drag springs and unbolt your front sway bar <-- heard that from someone on this board
Old Sep 16, 2002 | 09:54 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
getting real gears would help, at least 3.73
Old Sep 16, 2002 | 10:27 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
A two ton jack will probably do nicely .
Old Sep 16, 2002 | 04:38 PM
bob8748's Avatar
unbolt drivers side swaybar end link. Get some gears. battery in trunk... and yes... 2 ton jack would be easier.
The name of the game is forward... not up.
Old Sep 16, 2002 | 05:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My front end rises a lot from weight transfer but even I don't hike the front wheels up and I've seen video of my car launching. As nice as it looks, you can run quicker by keeping the wheels on the ground. Lifting the wheels is available energy going in the wrong way.
The easiest way is weight distribution. Third gens are very nose heavy. The more weight you can remove from the front or transfer to the rear, the easier it will be to raise the front end.
The trouble with producing lots of torque to pull the front end up is that you need to get that torque to the ground. Although it's possible, small slicks just don't provide enough traction to easily do it.
Watching a SuperStock car doing it looks easy but they also leave the line at around 7000+ rpm.
Old Sep 17, 2002 | 04:54 PM
brian89transam's Avatar
Are you sure about Ed Maher pullin wheelies? His car is a mostly stock 305 auto convertable. Headers, custom PROM, and Vigilante Torque convertor. I just can't see that combo doin gettin the front tires off the ground.
Old Sep 17, 2002 | 04:57 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Ed Maher doesnt pull the front wheels but he does get full suspension travel up front witht he sway bar disconnected.
Kat
Old Sep 17, 2002 | 05:03 PM
So was he just plain lyin or what?
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
wruiz
Aug 11, 2015 02:59 PM
