How do Lakewood Lower C.A.'s work???
Old Sep 23, 2002 | 01:44 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
They are very affordable, how much of an improvement over stock? I have wheel hop issues. Do they affect the cornering capabilities that much???
Old Sep 23, 2002 | 03:24 AM
vortechLT1's Avatar
I have em and love em they are alot better than stock
Old Sep 25, 2002 | 09:21 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have them, also. I am getting 1.64 60' times with them and a spohn torque arm.
Old Sep 25, 2002 | 09:26 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
i went from inconsistant 60' times from 2.0 - 2.3 on street tires to consistant 2.0s on street tires. stock converter and the only suspension work is lakewood CAs and lakewood panhard rod.
Old Sep 28, 2002 | 11:11 PM
Dan94GT's Avatar
Do the lakewoods have the drop down bracket which more or less does the same as the relocator brackets? Or can/do they work well in conjunction.
A pic would work too.
Old Oct 7, 2002 | 10:19 AM
Dan94GT's Avatar
TTT once again still wondering some things.
Old Oct 7, 2002 | 10:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No they do not. They are simply a square tubing replacement fo the stock parts. It would not be possible to make the brackets as part of the LCAs.
I have those, and Spohn reloc brackets and torque arm; I'd have to say that the single biggest traction improvement came from the reloc brackets. The other parts made a difference, kind of like takign rubber bands out of the suspension; the brackets completely eliminated the car's unbearable wheel hop.
Old Oct 7, 2002 | 02:38 PM
MdFormula350's Avatar
lakewood rear control arms helped my 1988 formula 350 alot. better lanching and stopped wheel hop in its tracks... for under 100 bucks they are well worth it..
Old Oct 7, 2002 | 02:47 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Originally posted by MdFormula350
better lanched and stopped wheel hop in its tracks... for under 100 bucks they are well worth it..
I concur.
Old Oct 8, 2002 | 10:07 PM
Dan94GT's Avatar
OK I must be thinking of their traction action lift bars. and everyone else is talking about the stock types. Anyone know anything about these. The standard stock replacement square ones are not what I am interested in.
Old Oct 9, 2002 | 11:37 AM
Marc 85Z28's Avatar
They are known for breaking with decent power and slicks. I've seen them break on the street on an 84Z, and all he had was an LT1 and Hotcam.
Oh, 330hp_91RS, yeah they work. They fixed my wheelhop problem. And for only $75!
Old Oct 9, 2002 | 12:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would not use those, especially on a street car. They are in essence a set of ladder bars. They can't help but bind whenever the wheels are deflected unequally, llike going into driveways or whatever. That's why that type of suspension is so good for drag racing: the car has absolutely no choice but to go in a straight line.
Don't get those, get the stock repacement ones that we're all talking about, and a pair of relocation brackets, and an aftermarket torque arm. I have Spohn TA and reloc brackets in addition to the Lakewood arms, it all fits right, works great, causes no problems, and launches hard. Like I said, the brackets did the most. I had wheel hop from hell, and in addition to that the whole rear of the car would fishtail under power (a 400 with a big roller cam etc.) I first got the LCAs, they tightened things up a bit; then I got the TA, that was like taking a huge rubber band out of the suspension, but the car still fishtailed; then I got the brackets. That completely fixed the entire problem. Now the rear doesn't squat, instead the wheels just dig into the pavement and stay there.
Old Oct 9, 2002 | 12:24 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Cool.
How does it affect the cornering capabilities. Make it stiffer/more prone to sliding? I still wanna be able to take the turns with some speed. I have major fishtail issues as well. if my front tires are not all the way straight when I powershift to 2nd, I'm all sideways.
How much are the relocation brackets and where can I get them??? Are they simply a bolt on procedure?
Old Oct 9, 2002 | 01:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It seems to improve cornering, especially forward bite. Doesn't seem to affect side bite or front/rear bias at all.
The brackets are absolutely NOT a bolt-in. They require welding. But, the welding is quite simple; it's the kind of thing any muffler shop should be able to do, for less than $50.
I got mine from Spohn, sponsor at the top of this page. They're about $65 IIRC.
Old Oct 9, 2002 | 04:15 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have sfc's, lakewood lca's, Spohn TA, and lca relocation brackets. For some reason I was getting wheel spin with slicks and the the relocation brackets in the bottom holes. I decided to put them in the middle holes. 60' times increased by a tenth. I then decided to try the factory location just to see if there was an improvement. There was. I get consistant 1.6 60' times now. I really don't understand why the brackets help everyones car except mine. I feel I wasted some time and money on the brackets.
1992rs/ss
Jan 31, 2025 05:10 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Street Lethal
Aug 14, 2015 08:25 PM
knight72
Aug 10, 2015 09:32 PM
