$400 labor to install $30 A-arm bushings?!?!
Old Oct 4, 2002 | 08:37 PM
formul8!!'s Avatar
Car: 2004 GTO
I got quotes from a couple of places to install my Energy Suspension A-arm bushings.
They all list it as a 2.6 hour job, EACH SIDE!!!
I'm thinking it's cheaper to buy the PA Racing tubular arms with the bushings already installed for $350 and put them in when I buy new struts and springs.
Old Oct 4, 2002 | 08:49 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Are they including the time it would take to disassemble and reassemble the front suspension or just taking your a-arms to them with the new bushings? If it's the latter, that's a bunch of crap. Find a new shop!
Old Oct 4, 2002 | 11:01 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
That's a good question, AT4 T/A. I could understand the price if they have to do all the dissasmebly.
Tom
Old Oct 4, 2002 | 11:34 PM
87 B4Z's Avatar
that price sounds about wright.
Old Oct 4, 2002 | 11:41 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I took my A-arms off and brought them to a machine shop. Cost about $20 to press out the old and press in the new.
Old Oct 4, 2002 | 11:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I usually go to the buzzard and buy an extra set for $15 or so ( of course I don't tell them I want Camaro ones since other kinds are the same), and slip the tech at the corner tire store a $20 around closing time on Saturday... no problem...
I hate doing those myself, it's worth springing the big $$$ like that to get somebody else to do it at my convenience instead of theirs.
Old Oct 5, 2002 | 09:02 AM
MikeC.86Roc's Avatar
That price is probably close, because that job is a Bitch... I tried pressing those bushings out, beating the hell out of them with a hammer, heating them, almost everything! Unless you have a collar to insert inside the a-arm and under the bushing when you are pressing them, then the arm ends will warp and bend. 350 bucks for the tubular set sounds like a pretty good deal, what brand was that and where do you get them? That's what I will do with my other Iroc if that's the case.
Old Oct 5, 2002 | 01:57 PM
flyway190's Avatar
I did the same and they charged me $15 per arm including pressing ball joints.
Old Oct 7, 2002 | 09:28 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I spent $40 myself at a local machine shop. I feel like I got ripped off. You must have got quoted a price for the complete disassembly
Old Oct 7, 2002 | 09:32 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
I paid $35 for labor when i brought the a-arms off the car with the old bushings, and new bushings in the boxes (they were kind of suprised that i had done this). A guy told me after i picked them up that they had pounded on them for about 45 minutes a side, and earlier i had tried a clamp-style bushing press, a torch, a sledge, and couldnt get the things to budge.
So i felt like i got a pretty good deal as well as saving me a lot of aggravation.
Old Oct 7, 2002 | 09:57 AM
merf23's Avatar
I jsut installed new struts, shocks, polyurethane LCA bushings and ball joints. Took me about 6 hours total. I ended up heating the bushings and hammering out the rubber part with a large drift. Then i using the cutting torch to cut the sleeves out and a chisel to get them out of the a arm. THe first one tool about 1.5 hours, the second about 30min since i had it figured out.
If you have access to a spring compressor the LCAs are not difficult to remove. It will save a lot of labor. Make sure you re-aling the front end with the new bushings.
Old Oct 7, 2002 | 10:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
People usually use an air chisel... 15 seconds, they're out of there. The new ones just pound or press in.
Old Oct 13, 2002 | 11:31 PM
breathment's Avatar
hehe. the guy at the shop i went to used an air chisel. took him over and hour!! but those suckers where in there TIGHT.. but with 200K miles. what do u expect.
cost $20 a side
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
TheExaminer
Aug 25, 2015 07:34 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
