What is the diff. in Front LCA's from 82-83 and 84+
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Just wondering why they sell the DEL-A-LUM suspension bushings in two part #'s:
Part# 1021 ( fits 1982 to mid 83) Price $129.08
Part# 1022 (fits mid 1983-92) Price $129.08
What is the difference in the two? are the front Lca's different? I had planned on either buying front tubular LCA's for my 82' (with spring perches) OR just rebuilding / powder coating the extra set I have for an 87 IROC, BUT it sounds like that may not be possible... Anyone shed some light.. lonsal, Steve Spohn, anyone?
Thanks in advance
Thanks in advance
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I've been wondering that myself for some time.
Another question is how do you know if your car is pre or post mid 83.
Is there a code or a particular manufacturing date etc.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Here's some useless info, the LCA arms off my buddies 78 Malibu are the exact same as my 86 Birds. Already checked out price differences and there is none.
Originally posted by mrr23
diameter of the shell that holds the bushings is all that would be different.
SOOO, will aftermarket tublar A's OR my 87' IROC with proper bushings bolt up ???
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
yes. all the factory control arms will fit. if you can get some tubular, then they'll fit also. so long as they say it will.
uh ok...
I've bought to many "WILL FIT" parts that DON'T..
just like a global west wonderbar won't fit an 82 because of the straight mount sway bar bushing (gm piece will fit
)SO anyone (or mrr23) done this?
SOOO...
I guess nobody know for tsure then huh? TTT
ambainb
Apr 25, 2016 09:21 PM
